#2325 |
Drives: 2013 High AT
Have been looking into a set of Konig Oversteer. They are available in 18x8J and 18x9J. according to carid the 9J won't fit the twins as the tyre sizes available are only 255/35/18's. I'd just like to know anyone else's opinions on this? As far as a I can see they are a 42 offset. If I could get away with 255's I would as I assume the grip would be pretty good. Much better than the 225's available from carid for the 8J setup.
#2326 |
Drives: Black BRZ
I ordered a set of 17x8 +32. I have stock suspension but plan on getting ST coilovers. I was thinking of going with 235/45 to keep my turn in response, but after reading through this I am thinking 245/40 will be better. Will I have any issues with 245? And is that too much tire if I stay NA for the time being?
#2327 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#2328 |
Drives: Toyota 86 GT
Front: 225/40-18 wrapped on Works Kiwami 18x8.5 +38
Rear: 245/35-18 wrapped on Works Kiwami 18x9.5 +38 Will this fit at stock ride height? How do you guys think it will look? And also how it will perform. |
#2329 | |
Drives: Black BRZ
Thanks for the info Killerbee. Do you know if 245 with +32 will rub? |
#2330 | |
Drives: 2013 BRZ Limited WRB
Interested in some RPF1.
Front 18x8+45 235/35/18 Rear 18x8+45 245/35/18 Or simply a square 245/35/18 if recommended. On a 0.6 drop. Any possible issues ?
#2331 |
that setup will fit good. it may poke 5-10mm in front depending on the tire brand, but it will not rub
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 Last edited by Killerbee; 05-04-2014 at 10:17 AM. |
#2332 | |
setup itself is good and will fit and look good
#2333 |
Drives: #1553 10 Series FRS
I'm sure this has been asked a million times, but I'm gonna ask anyway
Have 18x8.5 +38 ready to go on once tires get here, tires are federal rsr 245/35/18.. they run about 10mm wider so theyll end up being almost a 255. doing a square setup with ST coilovers. will they fit? lmao |
| The Following User Says Thank You to connorlug For This Useful Post: | Kilos6 (05-10-2014) |
#2334 | |
#2335 |
Drives: Scion FRS
Thinking of getting Work meister S1r, was going to get 18X9.5 +37 in the front with the big brake face, however im a little lost on the rear. I could get the 18X9.5 +37 in the rear with the deep dish face but is there another option to get something with more lip that will still fit 265s/275s in the rear? Maybe 18X10?
#2336 |
#2337 | ||
Sent from my SGH-I337M using Tapatalk
#2338 |
Oppa Gangnam Style!
Drives: Limited BRZ
Hey guys, I'm wanting to know if I get 18x8.5 +38 w/245/35 tires square would that fit at stock ride height? I'm also looking at down the road a little bit more to drop 1 inch so would I still clear? I played with the tire calculator and it appears I should be good but i'm wanting to double check that I'm not looking at it wrong. I'm wanting to get kinda close to flush, a little off is ok, so any suggestions on moving my offset even after a 1 inch drop? Thanks in advance for your guys assistance
Time moves on but memories last forever...
'13 Limited Dark Grey Metallic BRZ, Manual Transmission '07 STi, Cobb AP Stage 1, Invidia Cat back exhaust (Traded for the BRZ) '06 Nissan Sentra SE-R Spec V, Numerous Mods, mostly Nismo My Journal Last edited by Knightmare; 05-07-2014 at 10:38 PM. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
