#2297 |
Drives: Scion FR-S 2013 Raven
I want to know if it's possible to run 17x7.5 +53, they are from STI wheels V7.
Thanks!
o= FR-S =o |
#2298 |
Will this fit? (width, offset and tire size Qs)
Finally I found it, it's ok it will fit. http://www.ft86club.com/forums/showthread.php?p=639521
o= FR-S =o Last edited by Mikepage; 04-16-2014 at 11:53 AM. |
#2299 |
Drives: FR-S Firestorm 6MT
Yeah, they'll fit, just not the ideal offset but should be fine.
We'll call that fitment "ultra-tucked". |
| The Following User Says Thank You to Slick For This Useful Post: | Mikepage (04-16-2014) |
#2300 |
Because the wheels will be 5mm inside?
At least this is only 5mm
o= FR-S =o |
#2301 | |
Yours are 7.5" wide so add 6mm to each side (6+6 is 12mm =1/2") plus the 5mm difference in offset. So you end up with a wheel that is 11mm further in on inside and 1 mm further out on outside. The inside of your wheel is pretty much exactly where the inside is on my 18x9" +35 wheel. So it clears, but you are close to the strut on the inside whereas you have loads of space on the outside. A better offset for that size is between +30 to +40. You can also achieve the same offset by adding bolt-on 20mm spacers, which would give you an effective +33 offset. It's no biggie, just more of a looks/fitment/preference thing. If you like them, go for it. |
#2302 |
Thanks for the info, am not sure I will take it now :S I don't really want spacers...
But stock wheels are 7.5 also.
o= FR-S =o |
#2303 |
#2304 |
Ok my bad, thank you the info, you helped me greatly!
o= FR-S =o Last edited by Mikepage; 04-16-2014 at 03:09 PM. |
#2305 |
#2306 |
Am in Québec,Québec why?
o= FR-S =o Last edited by Mikepage; 04-17-2014 at 08:29 PM. |
#2307 |
18x8+40 wheels, with 225/40R18 in front and 235/40R18 in back.
First -- are these proper tread widths for that wheel width? (How does one tell?) Second -- assuming stock height/suspension, how much danger of rubbing fenders?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#2308 |
Drives: Sterling Silver BRZ
Curious if someone could confirm the fitment of the following as I can't find it with the search function.
F 18x8.5 +30 R 18x9.5 +40 Will be lowering the car by an inch probably. Thanks in advance for your help ! |
#2309 |
Drives: FR-S Ultramarine
I've try searching this thread without any luck. I bought a set of Enkei Tenjin 17x9 +45 offset. I've read that these wheel have a fitment issue if your running on stock suspension or spring. But I have coilovers, so I won't be having that problem. My main concern is what tire I should buy. I was thinking on getting 235/45-17 because I want to have a taller tire, as per the Wheel Directory the 245/40-17 will fit perfectly, but that would defy the purpose of getting a taller tire. So in conclusion I haven't found anyone that could assume me that the 235/45-17 will fit. Also I wouldn't mind going for a wider tire, as long that it would be taller than the OEM tire. Any help is appreciated.
#2310 |
Firstly, why do you want a taller tire?
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
