#2283 |
Drives: 2014 Whiteout FR-S
Hi all
Hope you can chime in. I bought 17x8.25 XXR 527's Was wondering if the stock Michelin tire would work (215/45/17) Think it would be a tiny stretch but want couple second opinion What size bigger would work? 225/45/17 or 245/40/17? Car is currently stock height and not tracked |
#2284 |
Drives: Toyota 86 GTS
Hi everyone,
Looking to keep the stock tyres (Michellin Primacy HP in 215/45/17) and keep the stock height. Is this wheel size ideal? 17x7.0 +38 Any point in have different sizes between the front and rear wheels? Cheers, everyone!
#2285 | |
1337
Drives: 2013 BRZ WRB S/C
Unless you are trying to go really fast in a straight line, or prefer the looks that wider rear wheels can give you - I would stick to same front and rear, makes it easy to rotate tires. |
#2286 | |
Thanks for getting back to me. You've made a very good point about keeping the front/rear wheels standard for tyre rotation, I hadn't considered that before. I just wanted to make sure that they would fit the stock tyres, wouldn't stick out past the arches and wouldn't need additional spacers, etc. |
#2287 |
Drives: 2003 FR-S
My Enkei Rijan wheels will be arriving very soon. The wheel shop only sells the ugly chrome nuts which I don't like.
A few questions before I go to pickup the wheels. First, can I use my existing OEM ones for the new wheels (just temporary)? Second, do I need the cone or ball seat for the Enkei wheels? I know the nut size is 12 x 1.25 mm. Should I pick the open end or close end nut type? Any differences? |
#2288 | |
Drives: FR-S Firestorm 6MT
You won't be able to use the stock lugs. Gorilla makes a great cost-friendly tuner lugnut, McGard are more expensive and have the washer-type seat. I've used both. My favorite are the spline-drive type. Like these: http://www.summitracing.com/int/part...83bc/overview/ or http://www.mcgard.com/index.php/auto...drive-lug-nuts |
#2289 | |
Drives: 2003 FR-S
#2290 | |
You're talking about $40 for a full set of Gorilla spline-drive lugnuts with a special key so that your wheels can't be stolen using a regular socket. Money well spent if you're investing in aftermarket wheels. Lots of performance shops in Markham should have them in stock. |
| The Following User Says Thank You to Slick For This Useful Post: | Gps360 (04-14-2014) |
#2291 | |
Drives: 2003 FR-S
Oh no no no, I am not being cheap out. I just want to know why the OEM wheel nuts do not fit (You just explained to me). Regarding the tuner nuts, I know most of them will have the paint chips problems. I really cannot find a store in Markham selling those Gorilla spline-drive lugnuts. Most of them are selling the Muteki and etc. (the fancy ones). |
#2292 | |
I bought wheels from Phil (the owner) eons ago, good guy, knows his stuff. 495 Denison St, Markham. [ame="https://www.youtube.com/watch?v=Cm5eKqmQpNo"]Automotive Import Market - (905)477-1771 - YouTube[/ame] |
#2293 |
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
fitment tool:
http://www.rimsntires.com/specspro.j...r%20H2%20wheel |
#2294 | |
Drives: 2003 FR-S
![]() Thanks a lot, I will try calling this shop |
#2295 | |
Good luck! |
#2296 | |
Drives: 2003 FR-S
![]() ![]() ![]() I was there buying snow tire package but not much choice at the first time. Steel rims were the cheapest package and wheel covers were free of charge. It was a very good deal for a poor student like me at that time. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
