#2269 | |
Drives: 2013 Scion FR-S Whiteout 6MT
Im not sure about brembo bbk fitment, remember backspacing also applies with bbks Good coilovers should be adjustable to give you ride quality to a point, and then stiffer for track days, maybe someone w more coilover experience can chime in however.. Sent from my iPhone using Tapatalk |
#2270 |
Drives: Subaru BRZ
Hey wheel aficionados!
I'm close to placing an order for TWS T66-F in the following fitment: F: 18 x 8.5 +42 R: 18 x 9.0 +44 OR 18 x 9.0 +44 all around What I wanted to know is will both these options fit with stock suspension? I do eventually plan on upgrading to coilovers but not sure how far down the line this will be. |
#2271 | |
Drives: 1990 BNR32 GTR
Preload, compression, rebound, etc will all affect ride. You can undo all the preload for more spring in the suspension, and soften the compression and the rebound to make the car literally bounce when it hits a bump. Likewise you can stiffen all that and make the car a rock. You can do everything in between.
#2272 |
Drives: BRZ Limited
will this fit ? 18 X 8.5, 55 OFFSET, 5X114 LUG PATTERN
#2273 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
That's a general guideline; it certainly doesn't mean that every wheel of that size will work. BBK manufacturers provide templates to help with this. More here: http://www.stoptech.com/technical-su...ment-templates. |
| The Following User Says Thank You to dradernh For This Useful Post: | tiz22 (03-30-2014) |
#2274 |
Drives: 2014 Satin White Pearl BRZ
So I finally ordered my SSRs in 18x9.5 +43 squared...but I just realized they put it down for the Super Low Disc. Will the super low disc cause any fitment issues? I dont know if this matters but ill be on no more than a 1.5" drop on coilovers. Hopefully someone can chime in asap so I can call to see if I could change it tomorrow! Thanks
#2275 |
1337
Drives: 2013 BRZ WRB S/C
#2276 | |
Drives: BRZ Limited
http://www.ebay.com/itm/SUBARU-IMPRE...20fb05&vxp=mtr |
#2277 | |
1337
#2278 | |
Drives: BRZ Limited
thanks |
#2279 |
1337
Stock height? The wheels be closer to flush than stock. Are you planning on lowering?
Stock wheel is shown in orange, the one you are proposing with 15mm adapters would look like the green. They should be pretty close to flush which is nice. |
#2280 | |
Drives: BRZ Limited
#2281 | |
1337
If you want to reduce wheel gap you have to lower it. All I'm saying is that the wheel will be less sucked into the wheel well. You are still going to have the same wheel gap as stock. |
#2282 |
Drives: 13 BRZ
I'm planning on buying 18x8.5 +44 for the front and back wrapped in either 225/40/18 or 235/40/18. What do you think will fit best and will I rub on stock suspension? I don't plan on lowering the car yet but I might get springs in a year time maybe to lower it from 0.5 to 1inch max.
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
