86WORX
go_a_way1
Old 02-11-2014, 05:48 PM   #2143
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Originally Posted by Slick View Post
When you add lowering springs, you will gain camber which pushes the wheel closer to the strut. So yes, you may rub depending on how much drop.
I was thinking of getting RS*R LOWERING springs, drops about 2". Will Coilovers eliminate that possible rubbing?
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 02-11-2014, 06:09 PM   #2144
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I've seen other people say this and I have to jump in, as it's incorrect, unless you're mixing up terms (shock/strut). The front is a MacPherson strut which is fixed solidly to the wheel spindle.
You may gain a teeny bit of negative camber due to lowering on a Mac strut, but the only way the wheel will get closer to the suspension is with crash/camber bolts since the wheel is affixed to the strut. Now, with camber bolts in the lower holes, I was pretty damn close to the strut with 17x8 +48. Putting them in the upper holes would be even closer or touching.
The rear suspension will gain much more negative camber upon lowering due to the upper/lower arm configuration. And since the shock is mounted to the LCA, the wheel WILL get closer to the suspension. Shouldn't be a problem back there, though, since there is so much more room.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Assunta (02-19-2014)
Old 02-11-2014, 06:11 PM   #2145
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
2" is a good drop, will be close but you may be okay. Some guys have run these on coils and it fits, barely.
See here, especially page 2.
http://www.ft86club.com/forums/showthread.php?t=30196
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
FLIPs_FR-S (02-11-2014)
Old 02-11-2014, 06:22 PM   #2146
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Thanks a million @Slick. I am in the next few weeks purchasing forgestar cf5 18x9.5 +38 for all four corners. 245/35 18 potenza R760 tires all four corners too.
Old 02-11-2014, 10:36 PM   #2147
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
So a 18x9.5 +38 with lowering springs will hit the suspension? I can't tell from the back side picture, it's a little blurred.
Sorry for the delay, saw u already got the answer but yes if u lower u will see a little more camber (depending how much u lower u will NEED camber to bring the tops of the wheels inside the fenders or ull rub like crazy) and every bit of camber u add will bring the edge of the rim that much closer (unless u get coilovers)
In the pic, green is the rim and the arrow is pointing to the spring perch (black), this is stock height stock camber
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
FLIPs_FR-S (02-14-2014)
Old 02-12-2014, 12:27 PM   #2148
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Okay, new question. Still the same 17x9 +45 wheels with 245/40 tires (8.2" tread width, so may go to the 255 for 9" tread, but only if that size doesn't rub.) but instead of lowering it on coils to make it fit, how about 10mm spacers? Effectively making it a +35 offset. It will probably poke a little, but that's okay. I think I could keep them from poking with a +40, but that would most likely rub.
Nevermore is offline   Reply With Quote
Old 02-12-2014, 07:25 PM   #2149
Slick
Slick's Avatar
It won't poke at +35. (poke is subjective though)
See my sig for pics and pretty much looks like jshadeck's car (rear fitment) at the top of the page too. Doesn't "look" like it sticks out much unless you put a ruler against it.
255 is a good size tire for the rim, ideal size actually.
Won't rub with a +35 effective offset unless camber settings are way off. You should try to be between -1.5 and -2.5 all around.
The Following 2 Users Say Thank You to Slick For This Useful Post:
2point0 (02-12-2014), Nevermore (02-14-2014)
Old 02-14-2014, 10:23 AM   #2150
Nsot
Nsot's Avatar
Drives: Whiteout FR-S
Sorry if something similar has been asked..
I have RS* Sports-i coil overs that I will install soon and 18x9.5 +40 Rays Gramlights 57C6 wheels on order. I don't think I will have a problem fitting these but I'm now looking for tires. I was thinking of getting 255/35/18 Michelin Pilot Super Sports but I keep reading that they run a bit wide.
Will these fit?
Thanks!
Nsot is offline   Reply With Quote
Old 02-14-2014, 01:40 PM   #2151
Slick
Slick's Avatar
Tires will fit the rims with no issue. Your camber settings will determine if the outside sidewall rubs the fender or not, but the Michelins have more of a rounded profile so I don't see an issue, plus some folks have run 265's up front and even 275's.
Will these fit?
Thanks!
Nsot (02-14-2014)
Old 02-18-2014, 12:49 PM   #2152
Junkwipe
Drives: Toyota Gt86
Hi guys. The xxr 522 in 18x8.5 measure what et they need for stay in safe fit (they can't stay out)
Junkwipe is offline   Reply With Quote
Old 02-19-2014, 10:23 AM   #2153
Slick
Slick's Avatar
Not sure I understand your question, what's best but won't stick out?
Best offset for an 18x8.5 would be between +35 and +40. The +35 will give you more poke, the +40 will tuck in a bit more. Both should clear stock coils.
Old 02-19-2014, 12:35 PM   #2154
Gps360
Drives: 2003 FR-S
Need some help guys,
Will the wheels with 18x9 - 5x114.3 with offset 35 and 215/40/18 tires (all corners) will fit to my stock 2013 FR-S? Currently, the OEM wheels are 17 inch.
With these specs, will the wheels tuck in or perfect flush with the fender?
I am thinking putting the Eibach Pro-kit later.
Thanks.
Gps360 is offline   Reply With Quote
Old 02-19-2014, 12:55 PM   #2155
Slick
Slick's Avatar
Thanks.
No issues, but without camber the wheels will poke a wee bit more, but your tires won't rub. I'm running 245/35R18 on mine with no issues.
Here is what it looks like on stock springs, wheels were on for only 3 days before spring swap:
And after the 1" drop on Eibach ProKit:
Old 02-19-2014, 12:55 PM   #2156
Slick
Slick's Avatar
Oh wait, you said 5x114.3 bolt pattern? That's a no go.
You need 5x100 for this car.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
