#1919 | |
Drives: FR-S Firestorm 6MT
Suggest getting springs or coils first if you go that route. Suggested tire is fine for that wheel size. |
| The Following User Says Thank You to Slick For This Useful Post: | FLIPs_FR-S (11-08-2013) |
#1920 |
KCCO
Drives: 2013 Raven Scion FR-S, AT
I just think we got shafted with the bolt pattern. Every time I see a set I really like 18x8 to 18x8.5. Then there is that damn 5x114.3 looking back at me.
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/ |
#1921 | |
Just a dude
Drives: Scion FR-S 2013
#1922 | |
Drives: Rx7
only the Impreza WRx, Forester and Legacy, Toyota Celica and CT200h has 5x100. That's a very small portion of the market to make 5x100 wheels. But since the release of BRZ/FRS, almost every manufacture are releasing 5x100 spec. However, it's only limited spec due to the very limited application that 5x100 can be use on. |
#1923 |
Drives: 2013 Subaru BRZ SWP 6MT
Any advice on getting alignment on the BRZ after getting new wheels and tires?
I need an alignment but know I may need to buy some additional components in order for the alignment shop to be able to adjust camber etc. Should I just get it aligned or would you recommend buying camber arms or crash bolts prior to getting an alignment? Currently running: -18x9.5 +44 square -5mm spacers all around -Eibach pro kit springs - stock struts Main usage: DD, freeway miles, city driving
![]() 2013 Subaru BRZ - SWP - 6MT |
#1924 |
Drives: 2013 SWP BRZ
Picked up a set of 17x9 +38 offset and will be running 245s, stock suspension right now minus whiteline camber bolts.
First off, wondering just how much poke I will have with about -1.5 camber up front and about -1 rear, as I'm hoping to have as little as possible. Second, are they're any concerns with rubbing with the fenders with this wheel and tire size? Finally, how much camber can I look at getting before I'm touching the strut? I'm planning on RCE yellows in the near future, but am worried about the increase in camber from the springs causing the wheels to touch the strut/spring perch. I run about 10 to 12 track events a year, so I'm hoping to get the setup dialed in where I can get more camber without worrying about rubbing both the fender edge or spring perch on the struts under high load. |
#1925 | |
Did you get it aligned after your spring install? You can get it to -2 in front with $4 crash bolts, but probably not needed unless you're trying to make the wheels fit better. You shouldn't need camber arms unless you're looking to dial it back. Don't go with more camber than -2 anywhere, you don't need it. I'd say stick closer to -1.5 all around if possible. 1/16" of toe-out on the front and 0 on the rear will make it handle well. |
| The Following User Says Thank You to Slick For This Useful Post: | ShoGun (11-12-2013) |
#1926 | |
On a 17" wheel, the closest to the spring perch is the tire sidewall, whereas on an 18" it's the wheelrim itself. You should be fine with a 245 though. You shouldn't have an issue with rubbing, though not sure what alignment you already have. Are you already at -1.5F/-1.0R? On stock springs, I doubt you'll be able to get much more than -1 up front with camber bolts. Stock is zero camber. I'm not sure on the Whiteline bolts, but factory crash bolts will give an extra .5 to .75 of negative camber. You will gain much more camber with the springs, since you gain camber with lowering. |
| The Following User Says Thank You to Slick For This Useful Post: | smbstyle (11-12-2013) |
#1927 |
Drives: '13 BRZ GBS
This is the following set up I'm thinking of getting:
18x9 +42, 245/35/18, with Eibach Sportline Lowering Springs. I know the rear will be okay. I'm worry about the front. I know there are some people running 18x9 +42 up front and have a couple of MM of clearance. Will I have any rubbing issue with the springs? |
#1928 | |
I only see one fitment of 18x9 +42 on the wheel directory (http://www.ft86club.com/forums/showthread.php?t=7535) and he's running coilovers, so you may need to run spacers or switch wheel offsets to make it work. Also, for reference, here's a 18x9 +38, see pics of how close it is to the strut. http://www.ft86club.com/forums/showp...89&postcount=1 |
| The Following User Says Thank You to Slick For This Useful Post: | BRZ323 (11-12-2013) |
#1929 |
Drives: 2013 CBS BRZ
Looking to fit 57 xtremes 18x9.5 +35 - 245/35/18 all around. Gonna be lowered on RCE yellows. Will these fit in the front the no rub?
#1930 |
Drives: WRB BRZ '13
Will this fit:
- 18x8.5 +33 (all around) - 235/40R18 (all around) - 15mm lowering (stock suspension + springs) |
#1931 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
17x8 +35 offset 245/45/17 fits all around no rub
#1932 | |
Tires are a good size, OEM diameter. |
| The Following User Says Thank You to Slick For This Useful Post: | TONYpepperon1 (11-13-2013) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
