#1891 |
Just a dude
Drives: Scion FR-S 2013
Currently I'm -2 all around but will be -1.5 all around next spring. I'm on kW coils yes.
#1892 |
Drives: FR-S Firestorm 6MT
#1893 |
Just a dude
Just find -2 to be abit aggressive, especially on rear we'll see. A slight less width on back may balance that some not sure.
#1894 |
I concur, our cars don't need as much camber as most do. I'm at -2.2 all around, track the car quite a bit and still find a bit more wear on the inside.
#1895 |
Drives: Toyota 86
Hey guys, finally found the wheels of my dream but they come in limited offsets.
18x9.5 +30 Square. Will they fit? I know theres someone who has run 8.5/9.5 staggered and said he said the slightly roll and flare the fenders which im fine with doing if required. All help appreciated
#1896 |
Drives: Raven Scion FR-S
correction** +33 will poke a little more than +40 ... but all in all he will fit fine
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#1897 |
Just a dude
The comparison was a 18x9.5" : 40 offset to a 18x8.5" :33 offset though.
#1898 | |
6mm more tucked for the 8.5+33 The other wheel is an inch wider so it's not a straight offset to offset comparison. |
#1899 | |
#1900 |
KCCO
Drives: 2013 Raven Scion FR-S, AT
Alright, here goes. I am very lost when it comes the wheel and tire setup. I would really rather not stagger mine when I buy aftermarket but I may have no choice.
How bad would this stick outside the front fenders. 245/30R19 on 19x9.5 ET35, only 2 companies make this size tire according to tire rack. Or 255/30R19, larger choice or tires in this size. Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/ |
#1901 |
KCCO
Larger choice OF tires** tapatalk wouldn't let me edit.
#1902 |
Drives: sc00ter
if anyone could help, would greatly appreciate it cuz i'm losing sleep over this haha
Will I be able to fit 255/35/18 with 18x9.5 et34 for the rear without any poking? I don't have any camber kit either and am lowered on coilovers.. |
#1903 |
So I just picked up some Weds Sport Sa-15r 18x8.5 squared setup +48 all around. I think the fronts is pretty close to flush at 1 inch drop, but im a bit lost with everything. Mind helping me out?
#1904 | |
It's a tight fit, more due to the wheel offset than the tire size, so you may need to pull a bit more camber in the front to make it work. Probably around 2.5-3 degrees. Rears will fit fine and the 255 is a better tire for that width, although a bit taller than stock. I'm sure you already know you will lose acceleration from the added weight of the 19s and the taller tire. |
| The Following User Says Thank You to Slick For This Useful Post: | FLIPs_FR-S (11-03-2013) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
