#1611 | |
Drives: Rocket Bunny v1 FRS
#1612 |
Drives: '13 BRZ
Thank you
what is the largest width i would be able to go with for rear rims if i was planning on staggering the setup? and would i be able to go with the same rubber specs for the rear if they were different in width?thanks, your a huge help! |
#1613 |
Drives: Scion FRS
How would the SSR MS3 in 18x9.5 +35 square work out? Should fit with 265s square as well with coils?
Would big brakes like the sti brembos work? Any rough idea? |
#1614 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
A question for you; I believe you stated you wanted flush or a more full rear. Priority over front poke BC you like rwd cars that way. Do you want/need a huge lip front and rear as well? Why not small lip front, big lip back? 8.5" front 9.5" rear.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#1615 | |
Drives: iG FR-S
Re: how wide - Depending on offset. 10.5" Width and offset is relative. You can do same rubber spec on different width but I never liked that idea. I feel it is weird. Doesn't flow for me. But that's me lol. Not my ride. :-)
#1616 | |
Drives: iG FR-S
Aggressive setup. No idea on 265 and coils. Probably tight... Let me do some quick math. Sti brembo should work. Recommend using a template before spending money or listening to me. :-)
#1617 |
Drives: iG FR-S
Probably clear with coils.. Getting tight. Def not on OE springs/perch
#1618 |
Drives: Scion FRS
Alot of people are running the 18X9.5 enkeis with 265s and the gramslights are fitting with 18X9.5 +40 and 265 so its a bit more aggressive. Hopefully I can order the ssrs and pray that they fit lol.
#1619 |
Drives: CX500 Cafe Bobber
I am thinking of these wheels…
Enkei RPF1 17x9 With these tires… Nitto NT05 255/40ZR17 The question is the offset, the wheels are available in either a +35 or +45; which would be best for overall fitment…? The only suspension mods I am looking at (for right now) are Swift lowering springs (either the Sports or the Spec-R, depending on drop & spring rates) & an SPC front camber bolt kit… |
#1620 | |
Drives: iG FR-S
Reference pic of similar setup- http://www.ft86club.com/forums/showp...postcount=1585 to see how much poke. The last few pages of this thread talk a lot about x9 sizing. Check it out and reply if you have any more questions.
| The Following User Says Thank You to ill86 For This Useful Post: | tinma (07-28-2013) |
#1621 | |
#1622 | |
Drives: 2013 Scion FR-S Whiteout 6MT
#1623 |
I figured that much and I appreciate the input! but I was also curious if the added wheel width might compensate for the ~1/2 inch of offset difference. but I guess not? I guess its just me but I cant stand setup where the front wheels stick out farther than the front... guess ill have to just run more neg camber up front...
#1624 | |
| The Following User Says Thank You to jshadeck For This Useful Post: | 86TruenoFRS (07-28-2013) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
