#197 |
Hi Tom, I know you have the Strano bar installed, have you had any issues with it shifting at all and are you using any type of collar? The stock bar uses collars and the Whiteline bar comes with them.
I also re-weighed the stock bar and Strano bar on a better scale and with bushings they are almost identical in weight. The Whiteline bar is still about 1.5lbs heavier than either one. In the end the Whiteline bar and Strano are about the same stiffness, so it comes down to whether you want the ability to adjust the stiffness depending on the surface. Or it may be best to use the Strano bar due to weight and stiffness and then just use shocks to adjust for surface. Decisions decisions. Good thing our first event of the year is a test and tune. Given how little wear I saw on the A6s I am expecting them to die from heat cycling before I cord them or wear them too much, especially rotating/flipping them. |
#198 |
Drives: 2021 Supra / 2022 Tundra
I didnt run mine long enough to have it shift around. On most bars I just put a piece of coolant hose around the bar and hold it on with a hose clamp to make my own collars. The BRZ went back to stock, long story there that's a bit off topic.
The Strano Parts 22mm hollow bar is heavier than originally planned because he ended up going to a stiffer wall thickness after testing it on his STX car. However I do think it's stiff enough that either will work for us. As you know, if you buy from Sam, you get his technical support which I've found handy. For others, full disclosure is Sam and I are friends, we are on the SAC together, but we became friends after being a very pleased customers for years. So a little biased but for good reason IMO. Keep in mind Whiteline tends to dumb down the adjustment range, their range isn't as broad as it sounds - do the match yourself to verify. However either will be around what I think is a good start for RTR or CS. Much better than without IMO.
TomR
#199 |
Drives: Firestorm FRS
I've got the Strano bar and think it feels great. Makes the car limits a lot higher, but also more balanced. Rear end still comes out but not at every turn of the wheel like stock. Guess this will also depend on your alignment.
Only have one event on it and that was 45 degrees and raining, but it felt good. |
#200 | |
#201 | |
Drives: ND2, formerly BRZ (MT/CBS)
I ran the Cusco 20mm bar most of last seaon and everyone who drove it (several very quick drivers, including P5 in RTR at nats) thought it was still a bit 'loose'. Last edited by jdrxb9; 01-08-2013 at 07:31 PM. |
#202 |
Good to know. Trying to do some parking lot testing this weekend maybe if the weather stays clear.
I finally got around to weighing my wheels/tires, the Velox PG-5S with the 245/40/17 A6s weighed right at 36lbs so about 24lbs less total than stock. |
#203 |
You might want to think about your rear toe. That 20mm solid isn't much softer than the 22mm hollow with thick tubing just the 22 is lighter.
TomR
#204 |
The Cusco is rated at 74% stiffer than stock, Sam's 22mm is rated at 85%.
#205 |
After nats, I dialed the toe back to only 0.11/0.12 deg L/R and it did seem to help a bit. Right now I'd say it is getting close to good. The theoretical calcs say the 20mm cusco is 152% of stock and Sam's hollow 22mm is 186%, so I'm hoping the 22 will do it.
#206 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Im jealous of you all; I want/need my front sway bar
#207 | |
Drives: Some rust bucket
OEM wheels with tires weigh about 40lbs. 40 - 36 = 4 4 x 4 = 16lbs savings |
#208 |
Just a note, I think you are using calcs from his site which I think he did before he increased the wall thickness just a touch. Sam knows for sure. But my original point is the 20mm solid/22mm solid should be in the range of what you need so I would consider more toe-in if you feel like the car is loose, not less.
TomR
#209 |
Drives: '13 BRZ in WRB--let's mod!!!
#210 | ||
| 2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 04:17 AM |
| What SCCA autocross class will the FRS be most competitive | SVThis | Tracking / Autocross / HPDE / Drifting | 5 | 07-30-2012 05:29 PM |
| Share/discuss (this mornin) 86 Newsletter... | RebootWindows | AUSTRALIA | 6 | 07-19-2012 05:15 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
| Discuss.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 02-11-2012 01:55 PM |
