Old 09-29-2012, 09:37 PM   #169
dsgerbc
Drives: BRZ(sold), STI
I thought I'd leave it here.
Some dude is selling a set of 17x7 +42 ~15lbs forged wheels. I'm not big on paying shipping on used rims and he didn't take my $600 shipped offer. But someone might be local or less of a scrooge than me, and could pick these up.
dsgerbc is offline   Reply With Quote
Old 11-21-2012, 05:17 PM   #170
bneale
bneale's Avatar
Drives: Scion FR-S
I'm bringing back an old thread from the dead here! I could probably have started my own but because this thread title matches perfectly, I'd thought I'd post my question here.
As some of you are already aware, I've been autocrossing my car in Stock class this season. Things are going great so far and thanks to Scion, I've been making quite a bit of money off the contingency program. So know I'm thinking I might buy a catback exhaust for the car. I've been looked Perrin's products and I really like them. But I'm a little confused with the rules and I'm hoping someone can clarify for me.
From what I can tell from reading the rules, the only kit I could buy from Perrin is the catback exhaust kit. But what about the overpipe? Is replacing the overpipe allowed in Stock class if you leave the cats stock? The rules are clear that replacement and removal of the cats is not allowed if the car is still under warrenty, so that eliminates the front pipe from Perrin completely. But what about the overpipe?
Could I just buy the catback kit and add on the overpipe? would replacing the overpipe be illegal for stock class because its infront of the midpipe cat?
I think I'm confused because the FR-S seems to have 2 cats.
Any help you guys can give would be appreciated.
bneale
bneale is offline   Reply With Quote
Old 11-21-2012, 05:38 PM   #171
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
SCCA and Canadian rules aren't the same. In SCCA removing any cat (or any piping before it) would move you out of stock class, and you can only replace a defective one with a similar one. So, no, you cannot do a new front pipe.
TomR
ABQautoxer is offline   Reply With Quote
Old 11-21-2012, 05:45 PM   #172
bneale
bneale's Avatar
Drives: Scion FR-S
Originally Posted by ABQautoxer View Post
SCCA and Canadian rules aren't the same. In SCCA removing any cat would move you out of stock class, and you can only replace a defective one with a similar one. So, no, you cannot do a new front pipe.
FAIL!!!
We're talking about the Overpipe Here. Not the same thing as the front pipe. You're probably just as confused as I am when looking at the exhaust system. This photo may help explain the difference. I think your first statement about "not being able to remove anythign before the cat" might be correct though. But thats why I'm asking. I'm confused. I think its because there seems to be more then 1 cat.
Also, if you read the CACC rule book, it says to refer back to the SCCA Solo National rules. So while your correct, your not exactly correct!
From the CACC 2012 rulebook:
7.3. STOCK CATEGORY
For Stock Category, please refer to Section 13 of the current year SCCA National Solo Rules.
Try again good sir!
bneale
Old 11-21-2012, 05:54 PM   #173
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
E. Any part of the exhaust system beyond (downstream from) the head- er/manifold or catalytic converter, if so equipped, may be substituted or removed provided the system meets the requirements of 3.5 and 3.3.3.B.15. Stainless steel heat exchangers are permitted only if the physical dimensions and configuration remain unchanged.
Modifications of any type, including additions to or removal of, the catalytic converters, thermal reactors, or any other pollution control devices in the exhaust system are not allowed and the system must be operable. Replacement catalytic converters must be OE if the vehicle has not exceeded the warranty period as mandated by the EPA. Converters must be of the same type and size and used in the same location as the original equipment converter(s). This does not allow for a high performance unit. If the vehicle has exceeded the warranty period, replacement catalytic converters must be OE-type as per Section 13.0.
Exhaust hangers which are bolted or welded on the car are consid- ered part of the body and may not be changed or removed.
Any portion of the exhaust upstream from the cat is illegal to modify.
And if you bothered looking up the diagram above to correct Tom, you probably also could have looked up the excerpt above just as easily.
Sccabrz192 is offline   Reply With Quote
Old 11-21-2012, 06:10 PM   #174
bneale
bneale's Avatar
Drives: Scion FR-S
See, I have already looked at the rules. I just found it to be confusing. Sort of like I needed a second opinion. I read the rules just as you did even before posting here. Hence why I was talking about the warrenty period in my first post. What confuses me is this specific part:
"Any part of the exhaust system beyond (downstream from) the head- er/manifold or catalytic converter, if so equipped".
From what I've been able to find, the header itself also has a cat included with it. So if thats the case, how do I follow the above rule? Are we talking about the header/cat here? Or are we talking about the midpipe cat?
For example, this appears to be the first cat (shown on the left) before the mid pipe cat.
If were talking about the header/cat thing, then I can see the overpipe being allowed. If we're only talking about the midpipe backwards, then I can see not being allowed the overpipe.
Hence why I'm so bloody confused.
bneale
Old 11-21-2012, 06:58 PM   #175
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I read it as, start at the tailpipe and work your way up, you can replace anything up to a cat or if there is no cat, the header, but that's my interpretation and the way i see it interpreted through stock class currently.
After you clarified your question I can see where your question stems from, but I guess my next question would be, what do you gain from replacing the overpipe if you still need to have an OE cat in the stock location downstream from it?
Old 11-21-2012, 07:04 PM   #176
ABQautoxer
ABQautoxer's Avatar
Originally Posted by bneale View Post
FAIL!!!
That's a messed up way to argue your point and its comical because you are wrong. You cannot touch anything from the rearward most cat forward. Overpipe is forward of that. So Front pipe, over pipe, etc you cannot touch. So you failed to understand simple rules.
EDIT: I would say I have an very intimate understanding of the SCCA rules, particularly stock class and kart classes. And I'm not confused on the exhuast parts since either own aftermarkets pieces or pre-ordered the exact ones in question.
TomR
Old 11-21-2012, 07:41 PM   #177
xwd
The rule should probably state "downstream of last catalytic converter" but that's what it means, like others have said.
Maybe have a little more tact next time.
Old 01-04-2013, 04:16 AM   #178
ayau
Drives: Some rust bucket
I'm currently selling my OEM Subaru crash bolts. They're brand new.
http://www.ft86club.com/forums/showthread.php?t=25138
Old 01-04-2013, 09:30 AM   #179
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
Can we run Front and Rear Strutbars in stock class? Like the Cusco Strut bars and Engine Powerbrace.
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 01-04-2013, 10:56 AM   #180
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
A front strutbar will put you into STX.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
The Following User Says Thank You to whataboutbob For This Useful Post:
kykiee (01-04-2013)
Old 01-04-2013, 11:09 AM   #181
ABQautoxer
ABQautoxer's Avatar
No Strut tower bars at either end. You can do shocks, brake pads, drop-in intake filter, catback, front OR rear sway bar, wheels that only the offset is different than stock by 6mm, shift knob, catch can (read up on this to make sure your's would be legal), and tires.
TomR
The Following 2 Users Say Thank You to ABQautoxer For This Useful Post:
kykiee (01-04-2013), whataboutbob (01-04-2013)
Old 01-04-2013, 12:34 PM   #182
kykiee
kykiee's Avatar
Well, I guess I'm going to STX class this year unless I remove the bar. What about the Cusco Engine Power Brace? I think that bumps me up to the STX class also.
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 04:17 AM
What SCCA autocross class will the FRS be most competitive SVThis Tracking / Autocross / HPDE / Drifting 5 07-30-2012 05:29 PM
Share/discuss (this mornin) 86 Newsletter... RebootWindows AUSTRALIA 6 07-19-2012 05:15 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
Discuss.... carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 12 02-11-2012 01:55 PM
