#15 | |
Drives: '13 Whiteout
Overall I'd say to learn the car first in it's stock form and build from there with aero being the last thing you add. |
#16 | ||
Drives: 2013 BRZ Sport-Tech
#17 | |
Spruce Goose is a flying boat and will lift on a wet track. If you are not very careful you will put the rear end into the wall on take off!!!!!
#18 | |
Drives: Crapcan
More instances of fuel starvation and oil starvation.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | CrowsFeast (05-31-2022) |
#19 | |
Drives: Track preped NA FRS
#20 | |
#21 |
Drives: Crapcan
Yeah, classing. Aero is typically on the higher dollar, higher end, less participated in classes.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#22 | |
Im not disagreeing with your initial comment on aero, just the reason. |
#23 | |
| The Following 2 Users Say Thank You to TommyW For This Useful Post: | CSG Mike (05-31-2022), Icecreamtruk (05-31-2022) |
#24 | |
Drives: Gr86
#25 |
Drives: Crapcan
T2's with 7kg springs. I mostly need to go up in spring rate, play with ride height, and work from there. The car feels okay most of the time, but on longer high load corners it starts to understeer at mid corner. It looks like I am bottoming in the front as it is chewing the hell out of the inner fender liners.
#26 | |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | NoHaveMSG (05-31-2022) |
#27 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Icecreamtruk (06-01-2022) |
#28 |
Drives: 2013 FR-S, 2017 BRZ
I'm in a very similar boat right now-- I finally have the front end grip enough that I like it, but I've destroyed the fender liners in just a few races.. I'm at the same static ride height I was before, but now it's tearing stuff up. I need to either go to stiffer springs or raise the car.
(APR GTC-200 with 3" splitter as well... KW Clubsports for springs, although I don't know what rates they are. they were on the car when I bought it. I need to do a little research on rates and lengths to get correct ride height before I spend any money on springs. likely also need to get the shocks revalved. I'll have some time this summer tho- next race is 3 months away but I'm fiddling with engine/oiling stuff right now and want to do some back-back testing with that, so I don't really want to change much on the car that would alter my lateral Gs and affect oil pressures in the corner. |
| FS: SARD LSR Style Carbon wing **wing only* | brzzy | Canada Classifieds | 3 | 03-23-2017 10:58 PM |
| Does anybody have seibon gt wing or apr gtc200 universal wing on their car? | spicyricecake | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-17-2016 09:38 AM |
| FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney | Enalband24 | Exterior Parts (Aero, Lighting, Etc.) | 10 | 01-03-2016 01:24 PM |
| Wing or no wing? (rear spoiler) | quik1987 | Scion FR-S / Toyota 86 GT86 General Forum | 123 | 12-12-2011 07:11 PM |
