#43 |
Drives: 2016 FR-S
What was the solution for this? Did you find a bushing that stood up to the heat or add some heat shielding? I have a ceramic coated ACE header and I just melted the Whiteline bushing that comes with their 22mm bar.
#44 |
Thats the exact same setup I have. From what I recall, I lined the area with heat reflective tape and haven't looked at it since. It hasn't melted a second time. I also moved the supercharger coolant lines up out of the way to let heat escape up through the gap between the heads and frame rail more easily.
#45 |
one more note the on Ace headers, my exhaust flange at the header separated from the collector tube. It looks like a very clean break, so I can't attest to ACE's welding abilities. Pulling it and putting on a JDL 4-2-1 header as soon as it comes in the mail.
#46 |
Drives: 2020 BRZ Sport Tech RS
ACE A350 headers are back in production / in stock! I had inquired with them a while back and didn't hear anything, and then out of the blue this morning I got this email:
"Our headers are officially back in stock with an improved redesign. Please have a look at our website for more details: https://aceheader.com/A350-GT86-FRS-...DER-p133843673"
| The Following 4 Users Say Thank You to Tatsu333 For This Useful Post: | AllThePeat (07-27-2022), Lantanafrs2 (06-30-2022), StraightOuttaCanadaEh (06-28-2022), villainous_frx (06-28-2022) |
#47 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
| The Following User Says Thank You to SuperTom For This Useful Post: | ballsdeep (06-29-2022) |
#48 | |
Drives: 2014 GT86
| The Following 3 Users Say Thank You to churchx For This Useful Post: |
#49 | |
Drives: 17 BRZ ,21 GR Yaris, 23 GR86
#51 | |
Drives: 17 BRZ
looks like the collector is shorter and after the collector the tubes are slightly longer to the overpipe flange. awesome! |
| The Following User Says Thank You to Espi For This Useful Post: | SuperTom (06-30-2022) |
#52 | |
Drives: Ocho-Seis
Looks can be deceiving! Unless there's an old vs new design side-by-side comparison with measurements, its all speculation. A write-up or explanation by the manufacturer of the improvements would be nice. |
| The Following User Says Thank You to ballsdeep For This Useful Post: | Espi (06-29-2022) |
#53 |
To me it appears that the primaries are exactly the same, but they moved the flange in the secondaries section further downstream (maybe to reduce turbulence by putting it in a straighter section?), and made the secondaries a *tiny* bit shorter overall, with the collector pipe being a corresponding little bit longer overall (which I believe is primarily for greater fitment compatibility between LHD and RHD models).
I'd guess that the changes were mostly done for fitment, and the fact that there may be a slight improvement in performance is just an added bonus...
| The Following User Says Thank You to Tatsu333 For This Useful Post: | ballsdeep (07-03-2022) |
#54 | |
Drives:
#55 | |
Drives:
#56 | |
Drives: 2018 Subaru BRZ
I would say yes. Like other tuners, it would take them a couple of runs to determine the best parameters. If you mean changing the headers and using an existing tune by D.T, it could work, but I wouldn't recommend it. Always good to optimize any upgrades done to existing equipment.
| Tags |
| ace, ace 350, aceheader |
| STI Lip Kit Discontinued? | ADabOfOppo | BRZ First-Gen (2012+) -- General Topics | 12 | 10-15-2015 12:08 PM |
| Top Speed Auto UEL Header Discontinued | raven1231 | Engine, Exhaust, Transmission | 11 | 09-28-2014 01:42 PM |
| FR-S / BRZ Discontinued? | Thatruth2001 | Northwest | 16 | 06-27-2014 04:30 AM |
| BRZ MIGHT BE DISCONTINUED AFTER ONE GEN?? | airjonny | BRZ First-Gen (2012+) -- General Topics | 37 | 06-24-2014 02:47 PM |
| openflash header replica? | toby714 | Engine, Exhaust, Transmission | 30 | 06-05-2014 03:11 AM |
