| BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
#57 |
Short term, mild mods for a street/canyon/track build. Double camber bolts, wheels/tires, quiet CBE, and pads/fluid. Most of these are done. Might add an e85 tune and hopefully pick up 15-20 whp with the oem cats in place.
Long term, we’ll see. If I start tracking regularly again, I’ll add my old track mods from my 1st gen. RCE T2 coilovers, wilwood BBK, and an aggressive alignment. Stickier tires. Any proven oiling mods.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Racecomp Engineering (02-13-2023) |
#58 |
Drives: 2023 SUBARU BRZ
Short term: Floorliners, winter tires and wheels, dash cam, etc
Long term: front bumper swap after the mid cycle facelift drops, new wheels once the stocks wear out, maybe some kind of lift |
#60 |
Drives: 2023 Wr Blue Pearl BRZ manual
Keeping it stock
2023 BRZ
| The Following User Says Thank You to Snoopysvet For This Useful Post: | vindiesel (02-19-2023) |
#61 |
Drives: 2023 BRZ
In order:
Android Auto Bluetooth adapter Hood struts Fire extinguisher Remove carbon intake filter Mount wheels and 10 mm spacers in front with CSG nuts. Ensure no rubbing on the rear fenders. Might have to use OEM wheels until camber gained through lowering. Overlays Detail and ceramic coat Tint and PPF Dash cam Trunk handle AOS Order Pilot Sport 5 tires from Next when I have 8” wheels. The Michelin Pilot Sport 5 will be available in 50 dimensions spanning in sizes from 17 to 21 inches when it becomes available worldwide on March 1, 2022. Goodyear Eagle F1 Asymmetric 6 is just as good all around, and a little quieter. Garmin Catalyst mount (research more) Nixspeed for Wheel studs Spacers BBK with pads and fluid Coilovers Front sway bar end links Oil cooler Horn Throttle pedal spacer Perrin steering rack lockdown when changing transmission fluid and engine oil Fumoto valve Differential cover when changing fluid
Director of Rocky Mountain 86CUP
| The Following User Says Thank You to Pat For This Useful Post: | RaceAddict (06-25-2023) |
#62 |
Drives: Mini Cooper S
#63 |
Drives: 2023 BRZ
I had it on my first gen car only. I could barely feel a difference after 100,000 miles on the original bushings. I took it off the first car and figured since I still have it I'd put in on my new one. If I didn't already have it I probably wouldn't buy it.
| The Following User Says Thank You to Pat For This Useful Post: | BioRebel (02-14-2023) |
| Which path to take o.O | Goz | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2015 07:37 AM |
| Need help deciding which path to take for suspension... | Lemar58 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 05-08-2014 02:06 PM |
| HELP with understanding Brakes upgrade path | bear89103 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 07-17-2013 08:08 PM |
| Upgrade path for Autocross | mechaghost | Tracking / Autocross / HPDE / Drifting | 7 | 07-30-2012 01:49 PM |
