| BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
#43 |
Drives: Miata
#44 |
Drives: 2018 BRZ
I tried both and found I prefer a lighter one. A weighted knob muted the feel of the shifter while a light one enhanced it. It also depends on the car - cable shifters appear to benefit more from weighted knobs than direct linkage.
| The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
#45 | |
Another thing to consider is in the long term, weighted knobs are going to accelerate wear of the shifter mechanism. It's why in your Owners Manual it states not to rest your hand on the shifter. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | PBR (05-23-2022) |
#46 |
Drives: Miata
I'm not even a fan of short shifters.
And I think a weighted knob is trying to make the short shifter, with the different pivot point, work better. |
#47 | |
Drives: 2018 Subaru BRZ Limited with PP
Raceseng seems to say there's no issue. But then again, they sell shift knobs, so they may not be the only source of choice. https://raceseng.com/blog/general/is...20transmission. EDIT: It's been a while since I watched the video, and now that I see it again, it doesn't necessarily have to do with the BRZ transmission in particular. More in general. Also to be more specific, resting your hand will also have a lot to do with how much weight you are actually putting on your shifter and whether you're moving it around a good bit or not. The point I mainly wanted to make was that weighted shift knobs, in particular, should have little to no measurable damage to the transmission or the shifting mechanism. Last edited by Dzmitry; 05-12-2022 at 10:52 AM. |
#48 |
Like riding the clutch. I've had people tell me 'I've rested my foot on the clutch for 100k miles without issue'. It's just not a good practice. As an enthusiast (and more so as a track person) I'm just offended by it, lol.
The fact of the matter is, no one is going to drive two identical cars under the identical conditions for thousands of miles so they can measure the difference in shifter linkage wear. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Dzmitry (05-18-2022) |
#49 | |
Drives: '23 BRZ Limited
If you meant to say it accelerates wear on the synchros, then yes, weighted shift knobs do that. Because typically it allows sloppy shifters the extra leverage to slam a car into gear that wouldn't otherwise go in. Are you the engineer there?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#50 |
It's a generic term to cover direct, linkage, or cable. They all have parts that slide/move that are susceptible to wear.
Good point on the heavy knobs forcing a shift. I know on the STi 6mt, the guide pads on the shift forks can wear out prematurely. It's a ton of time to replace a fork that only has a small worn-out piece of plastic. The symptoms of this are increased trans sounds into the cabin and vibration felt in the knob. I don't have any experience with the BRZ trans yet, to know if those same issues would or could arise. Yes. I'm the guy who has designed all of Killer B's products since 2009. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | CaptainFenderbaum (02-13-2023) |
#51 |
Drives:
Coils > wheels > maybe control arms if necessary
#52 | |
Could be wrong though, hence why I tried to do a good bit of searching on the subject prior to making my purchase. |
#53 |
...and the world will never know. We'll only ever have speculation here :/
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Dzmitry (05-23-2022) |
#54 |
Drives: Pavement MT GR86
MTEC clutch spring - installed
Camber bolts. Window tint all around. 25 and 50 Installed. Mod the airbox for induction noise, quiet catback of some sort for the eventual uel headers and tune. Small sub under the floor. Cheap 17 inch wheels and some AS tires here before November. PPF if I can find it for less than a paint job.
GR86 MT premium
| The Following User Says Thank You to StormTrooper For This Useful Post: | PBR (05-31-2022) |
#55 |
Drives: Ocho-Seis
BRZ Dual Air Oil Separator to be Released soon...
that's great news, will your offering be available by July?? |
#56 |
Drives: 2023 brz limited 6mt red
#1 pay it off
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
| The Following User Says Thank You to vindiesel For This Useful Post: | soundman98 (01-29-2023) |
| Which path to take o.O | Goz | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2015 07:37 AM |
| Need help deciding which path to take for suspension... | Lemar58 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 05-08-2014 02:06 PM |
| HELP with understanding Brakes upgrade path | bear89103 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 07-17-2013 08:08 PM |
| Upgrade path for Autocross | mechaghost | Tracking / Autocross / HPDE / Drifting | 7 | 07-30-2012 01:49 PM |
