Old 02-28-2022, 10:02 PM   #15
Robert97
Robert97's Avatar
Drives: 2022 GR86
"Currently, I am looking at Motul RBF 660 fluid ..."
Take a look at Castrol SRF. It has much better specs than Motul 660.
I just ran a track day with Castrol SRF and ds2500 pads on my 2022 GR86. The initial bite was about the same as OEM pads but there was more touch and control over the amount of braking, especially as the brakes warmed up. I'm a relative beginner so I'm probably not the hardest on brakes.
The ds2500s are good for street use. They do need to be warmed up a bit -- the first couple of stops on cold brakes require more foot pressure.
Robert97 is offline   Reply With Quote
The Following User Says Thank You to Robert97 For This Useful Post:
smg1138 (03-02-2022)
Old 03-01-2022, 12:44 AM   #16
CSG CP does exactly what you're asking for. Works ice cold, will tolerate track temperatures, virtually silent.
Winmax hasn't been distributed in North America for almost 3 years now.
kevaughan (03-06-2022), nathand (12-29-2022)
Old 03-01-2022, 09:18 AM   #17
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Originally Posted by SlowCarFast View Post
So I am looking for a brake pad upgrade with a few stipulations:
- 2015 BRZ Limited with ~21k miles
- I intend to do 2 track days (only 1 track day previously, so I am still a novice) and 4-5 autocross events this year. I want to get a set of pads that will be OK on the track and decent-good for autocross since I will be doing more autocross this year.
- Current tires are 225/45 pilot super sports with plenty of life left, but will most likely be shot by the end of the year.
- Currently pads/rotors/fluid is stock
- I intend to keep my stock rotors unless I need to upgrade.
- Suspension and everything else is stock other than an intake tube/filter and OFT tuning. I may do a header in a couple of months and a more aggressive tune, but not sure yet.
Currently, I am looking at Motul RBF 660 fluid and Ferodo Ds2500 pads. I realize that the pads are not great for track use, but I am trying to find something with cold bite for autocross and won't fade on the track. I am not opposed to swapping out pads to go to the track/autocross and back for street driving, but it would be great to have a pad that is tolerable on the street. I do not daily the car, so some noise and dust is not too much of an issue.
Am I making too many comprises here? Suggestions? Q
Sent from my Pixel 4 XL using Tapatalk
DS2500 will be great for your application. I've had C7 Z06 clients run them at VIR without fading them. They work great on the street, and rarely make any noise. They're easy on discs, easy to bed-in, etc. For AutoX they are hugely popular across a wide range of vehicles and they work great in that environment. We have many thousands of customers running these on a huge array of platforms (M2, 911, STI, Miata, S2000, Mustang, etc.). Here's an article I just wrote on Ferodo pads:
Which Ferodo Pad Compound is Right for Me?
As for fluid, don't worry about all the wet boiling point hype around SRF. Dry boiling point is your main concern. I examine that topic in this article:
How to Choose Racing Brake Fluid
Ferodo DS2500 front and rear plus two bottles of AP Racing R2 should do everything you need and then some. You can find the proper parts for your car in the links below. Everything below is in stock and ready to ship today. If you sign up for our email newsletter you'll get a coupon code for 10% off. Thanks!
Front Ferodo DS2500 for BRZ
Rear DS500 for BRZ
AP Racing R2
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
Old 03-01-2022, 09:28 AM   #18
Ohio Enthusiast
Drives: 2018 BRZ
That's a shame. I have a set of W5 pads and really liked them on track and autocross - great bite from warm to hot. Dust like crazy and squeal like stuck pigs on the street, but silent if kept bedded at the track.
Winmax always struck me as a good option thanks to wide range of compounds, public specs (full graphs for temperature and mu), easy naming convention and decent price. I was hoping to run W2/W3 on the street (once OEM wore out) and keep W4/W5 on the track, but looks like I'll be looking for an alternative. Any suggestions?
Ohio Enthusiast is offline   Reply With Quote
Old 03-01-2022, 03:19 PM   #19
CP if you want OE+, or just OEM for the street (a lot of guys will sell their like-new OEM pads for cheap).
On track? Depends. on your tire setup, aero, etc. There's not really a one-size-fits-all, but if the W5 worked well for you, the C21 will blow your mind.
Ohio Enthusiast (03-01-2022)
Search this Thread:
Advanced Search
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
2022 BRZ Dealer Stock Tip Thread slipstream8 BRZ Second-Gen (2022+) -- General Topics 12 12-06-2021 10:45 AM
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 06:27 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
