| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 | |
Drives: JRSC BRZ
| The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post: | Ohio Enthusiast (02-13-2022), saltywetman (02-13-2022) |
#16 |
ProCrastinationConsultant
There is technically 'no benefit' to my 18v drill having 2 speeds. But I use the 2 different speeds all the time for the torque advantage.
This patent will come into play, but more likely in the truck/towing market
#17 |
TRACKBREAD
Toyota EV. The savior of stick shift and rear wheel drive?
Have you guys looked at the diagram? There is no gearbox. It’s still just a direct drive electric motor and the pedals and shifter are connected to the motor controller, which then simulates everything.
![]() I want a low rpm (~10k) electric motor with a gearbox. Not a racing sim in an electric car. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | soundman98 (02-13-2022) |
#18 |
i'm too busy complaining to be bothered to click a link.
| The Following User Says Thank You to soundman98 For This Useful Post: | PulsarBeeerz (02-13-2022) |
#19 | |
Drives: '06 AM V8V Coupe
Motor efficiency is bad at low speed and high speed low load (eddy current losses in the stator, friction). 2 speeds lets you accelerate with higher efficiency and cruise with higher efficiency. If you were to build a more basic EV with 2 wheel drive and a more reasonable amount of power, 2 speeds would make sense. The nonsense about a gearbox being less efficient is nonsense, because Teslas have a 10:1 reduction gear before the differential. You can have two ratios no problem with on demand oiling. With a 4WD high power monster like the P100D, single speed makes sense for most situations especially with an induction motor or perhaps in the future a pure switched reluctance motor. I think a really fun EV sports car would be a rear weight biased, RWD, 2 speed "manual shift" with mechanical linkage, straight cut gears for some noise and transmission weight reduction, Torsen diff, maybe around 250hp/ton. Last edited by serialk11r; 02-13-2022 at 05:17 PM. |
#20 | |
Dismember
Drives: 2013 Red Scion FR-S
The base Model 3, RWD, has 272 miles of range, does 0-60 in 5.8 seconds, and hits 140 mph. Those stats look a lot like another RWD vehicle I know of. It also has a higher efficiency rating than the LR (AWD) and Performance (also AWD) models. If a 2 speed was the way to go, Tesla would be doing it. Also, not sure if you've driven a Tesla with regen turned off, but it's kind of stunning how little drag my Model Y has. There is less friction than anything I have ever been in. It's bizarre. The fact that the power goes through a fixed gear reduction is not the same as it going through a shiftable transmission. I'm sure some minor gains can be found with a transmission, but there are far more gains to be found in other areas: batteries, controllers, software, motor tweaks, aero, tires, bearings, and even optimized fixed gearing. Why? Because modern electric motors have gigantic efficiency ranges that cover 99% of driving.
#21 | |
Drives: '04 STi, '12 Mazda 3 Hatch
#22 |
| The Following User Says Thank You to Lelandjt For This Useful Post: | Yoshoobaroo (02-14-2022) |
#23 |
All this is no different than cars with CVTs that have fake shift points built in and give you impression that they are changing gears at "normal" shift points. Some even give you paddle shifters so you can pretend you have different gears.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | CincyJohn (02-14-2022), Dadhawk (02-14-2022), daiheadjai (02-14-2022), EAGLE5 (02-14-2022), Ultramaroon (02-14-2022) |
#24 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
It'll be all simulated, similar to EPS.
They sucked at it from the beginning but eventually manufacturers were simulate a real hydraulic steering rack with all the feel and feedback. I did read a pretty neat idea on reddit about EV manual, they could theoretically be programmed to mimic specific cars manual action and you could potentially be able to change the car's manual transmission profile to fit that car. Default to a sloppy Corolla manual shift action. Want to know what it feels like to drive a supra? switch to a supra profile. Want to try driving a porsche? Porsrche profile, etc. |
#25 |
Drives: 2022 MT Neptune GR86 Prem.
Yes - as much as a fan of MT as I am, I can't see ever wanting anything like this.
| The Following User Says Thank You to CincyJohn For This Useful Post: | Tcoat (02-14-2022) |
#26 |
Pavement Grey
#27 |
But if you crash you don't respawn in the middle of the road!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (02-14-2022), Ohio Enthusiast (02-14-2022) |
#28 |
1st86 Driver!
Tesla did try a two-speed transmission with the original Roadster. It was attributed with large part of their original delays.
Ultimately, if there is a legitimate reason for a transmission (such as increased top-end speed) I suppose it makes sense. I see no real reason for it in a street EV though. Extra complexity without any real benefit.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | EAGLE5 (02-14-2022) |
| A quick video tutorial on how to drive a stick shift:) | Andre Suwuh | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 03-17-2016 08:53 PM |
| Shift knob vs a shift stick? | DVNARC | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 09-13-2015 08:33 AM |
| Teaching wife to drive stick? | Nm86 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 03-26-2014 12:41 PM |
| TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? | No5ki | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 01-06-2013 09:30 PM |
| To Drive a stick or cruise an Auto? | MrFRsLa | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 04-30-2012 08:50 PM |
