| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#15 |
Drives: RX8 S1
Yes but on low beams only.
R8 had the whole shebang And yes 15k or so for the upgrade downunder (more like 5k stateside or in Europe)
#16 |
2 wheel member
Drives: JZA80, 997.1, Taco
Ah Tony, that was a Aussie $! Still 5K is steep for an upgrade.
btw, I kid you not, on my way to work this morning, I saw a convoy of Humvees leaving the Naval Amphib base in Coronado and low in behold, they had LED headlights! Those things were so bright even in the daylight and could be seen miles after I passed them. I guess it's closer than we think! ![]()
#17 |
Drives: Ms. Daisy
wonder if the duck made it...
BRZ before hoes
#18 |
2 wheel member
probably! The gunner is aimed in the other direction.
#19 |
professional smartass
Drives: 16 speed mountain bike...
We pulled a duck out of the space between a fender and the wheel well plastics in autoshop in highschool. That was a stench no one wanted to deal with and a bit baffling as to how it got there.
#20 |
Drives: Ms. Daisy
That sounds....disgusting.
On a related note, I wish our school had autoshop.
BRZ before hoes
#21 |
Drives: 300c
As you may know, most LED light bulbs will not work with a standard dimmer or with those fixtures with electric eyes that come on automatically at dusk or when a motion is detected. This is because LEDs require constant current to operate. If a standard dimming method is applied, the LED bulb will flicker at regular intervals, or worse, simply not work.
#22 | |
Hook 'em
I don't think LED is going to be a fad simply based on all the advantages they offer. They run cooler, draw less power, and have a much longer life than traditional filament bulbs. I wouldn't be surprised to see them also eventually replace HID headlights. |
#23 | ||
Drives: RX-8
therefore they are in premium brands like Audi, BMW as someone mentioned above.Quote:
= As far as using in headlights now, again cost. But the LEDs capable of auto use are readily available. The lenses in front of the LED make the beam pattern. For example I have a 3900 lumen 3 LED flashlight that is hella/blindingly bright and shoots far and wide. The best halogens have no more lumens than that each. ![]() It was only $55 and very similar to this one http://www.ledsupermall.com/uniquefi...lashlight.html. Heck, two of these could easily be headlights with the right lens I would think. Their output is nothing short of phenomenal!
#24 |
Drives: RX-8
And check this out, similar to the Humve, only $300
7" Round 12V LED Headlight by Truck-Lite Direct Replacement For Par 56, H6014 and H6024 Lights http://www.truck-lite.com/webapp/wcs...roductId=64057
#25 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#26 | ||
2 wheel member
It'll be a matter of time and a lot sooner before it'll be mainstream in automotive headlights. I think the task is having it aimed properly since we've already seen the intensity of it.
#27 |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
![]() Audi is probably the biggest investor in LED. On the R18 they complain about heat management though... they had to put a heat shield to protect things behind it.
I wish I was cool enough to have an FR-S
#28 |
Drives: RX-8
More points in favor of LEDs...
Aside from light output, LEDs everywhere in a car help designers to optimize many design goals. For example. it's possible to minimize weight in many ways. Items like wiring size, max alternator output, and battery size and capacity can be downsized due to less peak electrical demand. Because the LED housing can be less deep, there is some space savings possible and far more design leeway vs. i.e., bulky incandescent housings. Beam patterns can be more forused with multiple small LED lens vs a single light element and trying to make a single lens do everything. Light output color can be directly optimized for best visibility and clear lens can be used maximizing output in such elements as turn and stop lights. |
| What's up with Japanese cars and headlights? | CyberFormula | Other Vehicles & General Automotive Discussions | 22 | 04-14-2011 01:20 AM |
| What did you think about this year's automotive super bowl commercials? | iff2mastamatt | Other Vehicles & General Automotive Discussions | 5 | 02-08-2011 02:02 PM |
| Subaru's FT-86 Version still alive and coming confirms Automotive News | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 83 | 10-19-2010 07:19 AM |
| A question regarding xenon headlights | Go Mango | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-14-2010 10:14 PM |
| Top Automotive Fails of 2009 | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 8 | 01-28-2010 08:13 PM |
