#29 | |
Drives: Gt86 2013
The Evap codes I've been getting with the other ECM could be related? |
#30 |
Drives: Crapcan
What codes are you getting? Absolutely could be related. I was going to say, for your fuel trims being maxed the AFR is remarkably stable. I was expecting more dramatic fluctuations. That weird stumble it was also bouncing between closed and open loop.
#31 | |
Drives: Gt86 2013
P0301 Misfire Cylinder 1 P0453 Evaporative Emission Control System Pressure Sensor / Switch High Input P0463 Fuel Level Sensor "A" Circuit High P2401 Evaporative Emission System Leak Detection Pump Control Circuit Low P2419 Evaporative Emission System Switching Valve Control Circuit Low C1201 Engine Control System Malfunction That's weird that I never got them on my actual ECM Last edited by 02maher; 01-19-2022 at 04:20 PM. Reason: detailing |
#32 |
Drives: Crapcan
They may be stored codes and not active codes. If you are not getting them currently I don't think it is related. I would just check the simple things as far as leaks first and we can go from there.
#33 |
Drives: Gt86 2013
#34 |
TRACKBREAD
#35 |
Drives: Halo
spark plugs/coilpacks ok?
#36 |
Drives: Gt86 2013
The mechanic saw an oil leak on the driver side of the engine (not sure if it’s related to the issue) so we’re ordering the left valve cover gasket and spark plug tube seal to fix this issue and at the same time we’ll check for leaks and maybe swap some coil packs.
#37 |
Drives: Gt86 2013
It took me a long time to get the seals from USA as they didn’t have it here in UAE and Oman. So I just replaced them and fixed the oil leak and also swapped the coil packs and spark plugs from left to right but nothing changed in the drivability of the car and I’m still getting the same misfire codes P0300 P0301… We checked the exhaust for a possible leak too but couldn’t find anything. Could it be the intake manifold that’s leaking or something else guys?
#38 |
Drives: 2013 frs base
With weird symptoms, I always rule out a vacuum leak before going to other diagnoses.
#39 |
Drives: Gt86 2013
I removed and sealed again the air intake manifold but it didn’t change anything. So I just took it today to a garage that’s specialized in sports car but they’re a bit expensive… They checked the car for half an hour and they told me it’s definitely the direct injectors (su00304461) and quoted me 1200usd. What do you think guys *♂️ ?
#40 |
Drives: Gt86 2013
Update, just removed the port injectors and the direct injectors. DI looked all the same with intact and properly fixed O ring but quite dirty and with carbon built up. The port injectors on the passenger side where I’m having the misfire are both black (way darker than the other side). Took all the injectors to a specialist to have them checked and cleaned and he just told me that the dark injectors indicate a vacuum leak. Now where is this leak I don’t know but I might put a supercharger (sprintex 210) which will sit more heavily than the plastic intake manifold which can be problematic ??
If you guys have any leads where and what to check that would be much appreciated. |
#41 |
Just double check all of your hoses, connections, and seals when putting it back together. Hopefully, the leak will be fixed during reassembly.
#42 | |
Drives: Gt86 2013
I learnt that the engine uses sometimes more the port and sometimes more the direct injectors depending on the rpms and engine load, so I guess when I was soliciting the engine beyond a certain load at a certain rpm, it starts to use the DI and that’s why the misfire and shaking happen there. I’m getting a new injector soon and will keep this post updated for future reference. |
| The Following User Says Thank You to 02maher For This Useful Post: | blsfrs (04-30-2022) |
| Tags |
| clutch, evaporative, lag, misfire, system |
| Misfire after installing Crawford Billet Power Blocks (BPB) | LaertesSon | Issues | Warranty | Recalls / TSB | 39 | 04-14-2016 09:56 AM |
| Lack of power, can't figure out why (Supercharged, EcuTek) | EquiFox | Issues | Warranty | Recalls / TSB | 7 | 06-13-2015 10:48 PM |
| HKS Hi Power Spec L at 3,4&5k Rpms | Donbrz | Engine, Exhaust, Transmission | 5 | 04-06-2015 12:06 AM |
| FRS lack of horsepower | nmctacticz | Scion FR-S / Toyota 86 GT86 General Forum | 164 | 08-12-2014 12:18 PM |
| Poor response/power below ~2500 rpms? New car. | Formula Vee | Issues | Warranty | Recalls / TSB | 21 | 02-16-2014 03:33 PM |
