#15 |
Drives: Gt86 2013
#16 | |
You could try retuning it. Use the same map, or it was my understanding that there was a library of OFT maps. Perhaps there is a different one that will behave better. Have you checked your air filter? Run seafoam/fuel injector cleaner? Sent from my ONEPLUS A5010 using Tapatalk |
#17 | |
Drives: Gt86 2013
#18 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Tcoat (01-19-2022) |
#19 |
Drives: Crapcan
You have an OFT, do a datalog, bet your IAM is low.
Start here. https://www.ft86club.com/forums/show...01#post1842501 Upload to datazap. https://datazap.me/ Post link. Get Help. Profit.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#20 | |
Take about 5 octane off any European (used in Dubai), Aussie or Japanese numbers . Still stuck on what the tune is. If the stock cars were faster then why not just go back to the stock mapping and see what happens? I think there is more to this story someplace.
#21 |
As mentioned above if you have an OFT device, then datalog and post. That will show what's going on with your engine.
2022 BRZ Build 2013 FR-S Build |
#22 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
How about your wheels & tires set up? What's are their sizes? What's their weight?
Sent from my SM-G781W using Tapatalk
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
#23 | |
Drives: Gt86 2013
https://datazap.me/u/02maher/log-164...og=0&data=1-13 https://datazap.me/u/02maher/log-164...og=1&data=1-13 |
#24 | |
Drives: Crapcan
Get car to operating temperature. Cruise at a steady RPM for a few minutes, and then post it. It is easier to see issues at steady state but from what you posted your fuel trims look jacked up. It is harder to see when you are on/off throttle a lot. Looks like you have an exhaust leak though. Looks like you are on a V4 tune as the IAM starts at .7, it does climb to .73 which is a good sign.
#25 |
Drives: Crapcan
Also, remove "boost" and add "injection mode" to the log. You do that on the OFT in a menu with what parameters you want logged.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Yoshoobaroo (01-19-2022) |
#26 |
TRACKBREAD
IAM goes to 1 in the second log so fuel quality is probably fine. Fuel trims are definitely indicative of an exhaust leak near the O2 sensor
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | NoHaveMSG (01-19-2022) |
#27 | |
Drives: Gt86 2013
https://datazap.me/u/02maher/log-164...5?log=1&data=1 https://datazap.me/u/02maher/log-164...5?log=2&data=1 Last one illustrates the shaking that I'm experiencing after 2300rpm, still on certain occasion it's worse than that... If there is an exhaust leak is it most probably before the headers? |
#28 | |
Drives: Crapcan
Simple stuff first. I would check where the header mounts to the cylinder heads, you may see black soot where it is leaking. I would also check from where the header mounts to the overpipe, and around the O2 sensors. An indication it is leaking would look like this picture. See the soot?
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | 02maher (01-19-2022) |
| Tags |
| clutch, evaporative, lag, misfire, system |
| Misfire after installing Crawford Billet Power Blocks (BPB) | LaertesSon | Issues | Warranty | Recalls / TSB | 39 | 04-14-2016 09:56 AM |
| Lack of power, can't figure out why (Supercharged, EcuTek) | EquiFox | Issues | Warranty | Recalls / TSB | 7 | 06-13-2015 10:48 PM |
| HKS Hi Power Spec L at 3,4&5k Rpms | Donbrz | Engine, Exhaust, Transmission | 5 | 04-06-2015 12:06 AM |
| FRS lack of horsepower | nmctacticz | Scion FR-S / Toyota 86 GT86 General Forum | 164 | 08-12-2014 12:18 PM |
| Poor response/power below ~2500 rpms? New car. | Formula Vee | Issues | Warranty | Recalls / TSB | 21 | 02-16-2014 03:33 PM |
