Old 04-05-2022, 04:26 PM   #57
Originally Posted by rice_classic View Post
Find the pad that maximizes the front tire deceleration then use a rear pad that compliments that; in my case a rear pad that induces “just enough” rear abs as the very limit or under late stage trail braking is ideal.
Think about heat. Stock brakes with no cooling and r-comps = lots of heat. BBK with brake ducks and 200tw tires = very little heat. Run the corresponding pad.
Tracks with unique conditions can induce strange realities too. Example, on the racecar the ST43 rear pads will last a full race season+ on PacNw tracks (and california) but in (1) 40 minute race at Road America they got destroyed. RA has 3 hard decel zones from 120+mph which is unique vs most other tracks. If I raced at RA often I would either run a “hotter” pad in the rear or add rear brake cooling.
Rather than heat, I'd encourage you to think of it in terms of response and release.
You're an advanced enough driver that you really should be thinking beyond just heat vs friction generated. By now, you've probably noticed that there's really no correlation between how a pad feels (subjectively AND objectively) and a published heat/friction number/curve.
You've clearly developed your own preference for both response and release, and then found a setup that accommodates you, but like you said, it can change situationally. There are pads out there that will give you the lower friction you want AND handle Laguna/RA type tracks at the same time.
Old 04-05-2022, 05:51 PM   #58
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I am convinced that heat must be solved for first which is reason I spoke to that without muddying the waters. Great release and response is secondary if your pads are overworking abs, grooving your rotors, laying down uneven transfer layers or are fading. You can drive around some release/response characteristics and still be fast, it's hard to be fast if managing pad fade or uneven transfer layers.
In other news - The GLOC guys are seemingly very engaged in SCCA racing contingency and have been working well for Hayai (both the pads and the customer service). Since I'm worried about Runoffs this year (not attending) and I'm doing more local races this year, I may sport some GLOCs once Hayai has finished finalizing his preferred compounds with them.
Here's the problem with racing - even if you tested a bunch of stuff and found the "winning formula" - after you've been using that formula for awhile it's VERY easy to be attracted to wanting to try other options just "in case" something else is faster. Brake pads and tires being the most attractive of the bunch.
SCCA T4 - FRS
Old 04-05-2022, 06:20 PM   #59
Precisely why testing is king!
You'd laugh if you see some of the posts I've made selling used pads that have maybe half a mill of use, and tires that have 2 cycles on them
evanescent03 (04-20-2022)
Search this Thread:
Advanced Search
Recommendation for GTA PDR? 1Cor10:23 CANADA 12 11-08-2014 10:08 PM
Brake pad and fluid install shop recommendation(south florida)? becauseracecar1 Southeast 3 04-21-2014 11:32 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 06:34 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
