Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 02-10-2022, 12:53 AM   #155
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Originally Posted by Up4speed View Post
I haven't driven the car yet, but if I remember correctly from reading up on the car, I think owners were also saying that the throttle behaved way better, faster, and more predictable, when at higher RPM's, like when on a race track.
Yeah, I definitely remember hearing that! This break-in can't end soon enough. Snow and late-night maintenance shifts have banished me.
Panda Grahams is offline   Reply With Quote
Old 02-10-2022, 12:56 PM   #156
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yep, in my experience the throttle behaves much better when really thrashing the car. It also has the same horrible dead/lazy throttle behavior that the first gen had if you disconnect the battery. I didn't test to see if a throttle re-learn like the first gen would help.
Old 02-11-2022, 12:54 AM   #157
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Tunes will be available soon enough, that will include a fix for this.
Midnightsky is offline   Reply With Quote
Old 02-14-2022, 11:05 AM   #158
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
I found my first quirk on a road trip this weekend...
The sun visors are terrible. When pulled down they leave a large gap between the outside edge of the visor and the A-pillar which renders them almost useless.
Heading due west this time of the year at my latitude, the setting sun will often sit right in that gap and the visors don't block anything.
Desertnate is offline   Reply With Quote
Old 02-14-2022, 11:19 AM   #159
CluelessPedalMasher
Drives: 2022 BRZ Limited AT White
A quirk I noticed is how the stability control reacts to holes when braking at low speeds. I live in a bumpy city and when pulling up to a light there's usually pot holes on the left side of the lane. Braking from about 15 to 0mph, if I go over a couple of holes, the stability control start dragging me left and I gotta correct. This is the only time it happens and I'm used to it now but just wondering if anyone else ran into this?
CluelessPedalMasher is offline   Reply With Quote
Old 02-14-2022, 11:53 AM   #160
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Can someone tell me if their heated seat buttons are backlit when its dark/at night?
Its one of the things ive noticed with the first gen...all the interior buttons are backlit red except the heated seat buttons (i think the side mirror adjust knob is also not lit). Only way you'd know its there is if they are on and the high/low setting lights are on.
found it a bit weird that these arent backlit in the first gen. I suppose it might have something to do with them not being available on the base model car.
Old 02-14-2022, 12:16 PM   #161
Desertnate
Spelling Impaired
Pretty sure my heated seat button's are lit. They sit so far back they are out of sight most of the time. I do remember being able to easily find them to turn them off in the dark this weekend.
I've not found any unlit buttons in the interior so far.
The Following User Says Thank You to Desertnate For This Useful Post:
Sasquachulator (02-14-2022)
Old 02-15-2022, 01:45 PM   #162
Burrz
Drives: 2022 BRZ
The 8" infotainment system is quirky. Often when I try to adjust the volume using the knob my finger triggers the touch screen in the top left of the screen, switching to FM Radio. My finger wasn't touching the screen, just the edge of the plastic frame. I also do this sometimes when trying to adjust the volume from the steering, if I brush the wrong button. Very sensitive!
At first I thought it was a bug, "Adjusting volume switches to FM", but came to the realization it was just touch sensitive and with consideration the issue is minimized.
Burrz is offline   Reply With Quote
The Following User Says Thank You to Burrz For This Useful Post:
tenderization (02-16-2022)
Old 02-15-2022, 01:52 PM   #163
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
In the first gen, they only light (amber) when you turn them on.
CincyJohn is offline   Reply With Quote
Old 02-16-2022, 12:14 AM   #164
Midnightsky
Confirmed, on my 22 Sport-Tech they are illuminated.
The Following User Says Thank You to Midnightsky For This Useful Post:
Sasquachulator (02-16-2022)
Old 02-16-2022, 10:11 AM   #165
Desertnate
Spelling Impaired
In case there was any question in a US vs. Canadian spec, I checked last night too. In my Limited, they are fully back lit as well.
Old 02-16-2022, 02:06 PM   #166
Sasquachulator
Pavement Grey
Another quirk for you 2nd gen owners:
Is there a trunk grab handle in the second gen?
I wish there was one in the first gen to pull it down to close. Right now i pretty much grab the emergency trunk release latch enclosure and then the edge of the trunk deck right under the spoiler to slam the thing down to close it (since it requires a surprisingly hefty amount of force to close.....with that said....does the second gen need that much force to close the trunk?)
Old 02-16-2022, 02:28 PM   #167
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
No handle built in, but you can use the rubber bumpers on the lip as a handle. Not much force to close.
dragoontwo is offline   Reply With Quote
Old 02-16-2022, 02:55 PM   #168
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
No handle, but I've been closing it via the ends of the black trim piece that runs across the trunk. Seems to work.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Search this Thread:
Advanced Search
BRAINDUMP - FT86 Quirks, common fixes and when things need upgrading Aztec Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2015 06:44 PM
Magazine features crouchy35 AUSTRALIA 1 06-03-2013 06:59 PM
Interesting features on the FR-S... Senzai Scion FR-S / Toyota 86 GT86 General Forum 59 05-08-2013 05:41 PM
Strange Quirks Aznek Scion FR-S / Toyota 86 GT86 General Forum 30 08-15-2012 10:40 AM
FR-S Standard Features zAnSh1n Scion FR-S / Toyota 86 GT86 General Forum 182 04-04-2012 05:23 PM
