Old 08-15-2012, 09:51 PM   #15
jm1681
Drives: MKVI VW GTI
I actually played with this theory today, and it does prove true best I can tell. I was coming around an on-ramp earlier with miles of space all around me. I sped up (Still WELL within comfortable control), then backed off a bit mid-apex.
The back DEFINITELY started to rotate, but not to the point of squeal, it was just a well defined feeling of rotation. Now, this was also at VERY reasonable speeds over a very wide turn, so in tighter, faster situations, I would expect the results to be equally more dramatic.
Soon as my break-in is complete, I REALLY want to hit an auto-cross as soon as possible to see just what happens when I'm pushing. Rather figure it out when all I stand to hit is a cone, versus another car or something decidedly more solid.
jm1681 is offline   Reply With Quote
Old 08-15-2012, 11:41 PM   #16
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
Originally Posted by pr086 View Post
but thats the thing, in a FWD car you could lift any time any place and its not going to make a difference. at least in my car.
Depends on the car. Lift off mid corner in my CRX and holy hell snap oversteer. Cars that have a strong front weight bias tend to snap oversteer easier than ones that are more evenly balanced.
neutral is offline   Reply With Quote
Old 08-16-2012, 12:23 AM   #17
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I am still getting used to the off throttle oversteer. I would think I would be used to it coming from Imprezas, but it is a different feel all together for sure. I have had a few "oh snap" moments, nothing too bad, but being that it is not my car, it does make you pucker up just a bit lol. I do love this car though, and am now even tapping the brakes mid-corner just to get that weight transferred forward, quickly followed by throttle. It does make me giggle like a little school girl LOL.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-16-2012, 12:35 AM   #18
Benzy
Drives: 2001 Camaro
If I may interject here with a question, what is 'lifting'?
Benzy is offline   Reply With Quote
Old 08-16-2012, 12:37 AM   #19
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Gas all the way!! Never let up or this car will eat you alive! 2 poles avoided because of throttling out and stock tires. I can only imagine how it handles with good rubber. Been side ways a few times and I've never drifted b4 and this car helps you through it. Punch it next time.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 08-16-2012, 12:41 AM   #20
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Your car is then setup to understeer like a stock FWD car. In a FWD car setup for the track or a racing application the understeer inherent to FWD will be dialed out and if you lift you will lose it. Driving a FWD fast through a corner is more "committed" then RWD because you can't modulate the rear with the throttle and thus a "lift-throttle" when at the limit usually ends up with the driver facing traffic.
In fact, "Don't Lift" is a FWD racing mantra.
Examples I'm not proud of:
So Folks, before you subscribe to any "saying" please keep in mind what the specific setup is on any car before approaching the limit. Also, it is my experience that the FRS is quite prone to LTO with the Nanny State turned off.
Old 08-16-2012, 01:01 AM   #21
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Lifting off the throttle
daiheadjai is offline   Reply With Quote
Old 08-16-2012, 02:50 AM   #22
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
When you lift at the limit on a corner the weight is transferred from the inside rear to the outside front. If your going fast enough you will lose rear traction causing oversteer toward the outside. A lot of other things come into play as to how bad you will slide. Front, rear or Awd will all transfer weight the same way without some sort of stability control stepping in. Quick reflexes and seat time is all you can do to,save yourself or prevent it from happening. I've done it a few times on purpose in competition but I don't recommend it if there's a wall. Be careful.
GenkiElite is offline   Reply With Quote
Old 08-16-2012, 09:52 AM   #23
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
what if you're at the limits of grip in a long corner, 50% throttle, and the rear starts coming out? what do you do in that situation?
I'd gently apply throttle and countersteer.
iLuveKetchup is offline   Reply With Quote
Old 08-16-2012, 10:20 AM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I love Lift-throttle oversteer. Best feeling in the world, IMO. Set up for a corner, turn-in, then lift for a fraction to get the rear to stand up and shift, then back on and through the corner.
Of course, I do a LOT of SCCA RallyCross.
No e-brake needed:
[ame="http://www.youtube.com/watch?v=b3FI3Yfa94E"]071911 WOR RallyCross Afternoon Run#5 - YouTube[/ame]
But when it comes to tarmac, letting the rear end out is not the fast way to do things. Keep it tight and don't upset the car for the best times. I'm a little too slide-y for my own good when it comes to tarmac racing and place mid-pack usually.
Old 08-16-2012, 12:01 PM   #25
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Originally Posted by Pekingduck View Post
Always look where you want to go also tend to help.
This!!
DjDATZ is offline   Reply With Quote
Old 08-17-2012, 10:58 AM   #26
trinitron
Drives: gts 86
[ame="http://www.youtube.com/watch?v=vnhiFucXoVk"]Mk2 Toyota MR2 Snap oversteer. Slow down BEFORE th - YouTube[/ame]
You should always slow down before the corner and gradually apply throttle throughout your turn until you're straight again.
If you are going fast into a corner never lift but if you find yourself in a position where you have, countersteer against it.
trinitron is offline   Reply With Quote
Old 08-17-2012, 12:49 PM   #27
Quixote
Drives: E90 M3, Blue GT86
Beware arm chair racers...learn for yourself...
I highly recommend http://www.skipbarber.com for their courses - not cheap, but you get what you pay for...a while back I did a driving course at Lime Rock - I've never been so fast so smoothly as I did with one of the instructors there...
Just think of the 'cup of water' training example - it teaches you to be progressive in all things. Skip Barber use something similar.
Then of course there's the skid pad exercises which are fantastic if you want to learn how to control the car properly when the tail is out
Quixote is offline   Reply With Quote
Old 08-17-2012, 12:51 PM   #28
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I agree i just finished there 2day high performance school YESTERDAY it was my second skippy school you learn so much!
Lee358 is offline   Reply With Quote
RedLine Tuning Hood Quick Lift tonystewart Cosmetic Modification (Interior/Exterior/Lighting) 4 12-15-2012 01:28 PM
Home Car Lift SEC Other Vehicles & General Automotive Discussions 10 08-20-2012 11:17 AM
New Official WRB Subaru BRZ Video from Geneva "Lift" gt86mods BRZ Photos, Videos, Wallpapers, Gallery Forum 13 03-06-2012 11:25 PM
