Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 12-15-2021, 05:48 PM   #253
Strat_FRS
Drives: 2015 FRS for daily and track use
So just so everyone is aware, STD correction is about 4% higher than SAE. I find that SAE correction is what you want to use on naturally aspirated motors as atmospheric pressure and temperature effects are very well accounted for by the SAE correction factors especially if the dyno is done at different times. For turbocharged motors because pressure and temperature have a skewed effect due to the compressor staying between ambient pressure and temperature SAE and STD compensations start to deviate the higher you move away from 1.0 compensation factors (high altitudes etc).
Strat_FRS is offline   Reply With Quote
The Following User Says Thank You to Strat_FRS For This Useful Post:
DocWalt (12-16-2021)
Old 12-15-2021, 06:02 PM   #254
FrickingReallySlow
Drives: 2015 FR-S
260bhp...The ShortBlock is strong with this one...
a very reliable 400bhp FI + E85 build is in the cards 2-3 years down the road! gimme that FA24 shortblock SOA!
FrickingReallySlow is offline   Reply With Quote
Old 12-15-2021, 07:31 PM   #255
sds
Drives: '22 BRZ Limited 6MT
What I find more compelling is that the second gen makes 25% more power at the wheels than the first gen (according to OpenFlash's dyno on the last page).
sds is offline   Reply With Quote
The Following User Says Thank You to sds For This Useful Post:
DriveDriftDogfight86 (12-16-2021)
Old 12-16-2021, 01:30 AM   #256
soilent
Drives: 2022 BRZ Premium
20% bigger engine with a better flowing stock header and I'm sure some other improvements. Makes sense to me.
soilent is offline   Reply With Quote
Old 12-16-2021, 02:37 AM   #257
PulsarBeeerz
Drives: JRSC BRZ
Dirty over lay of MY13 stock vs MY13 FBO vs MY22 all on gasoline.
PulsarBeeerz is offline   Reply With Quote
The Following 6 Users Say Thank You to PulsarBeeerz For This Useful Post:
DarkSunrise (12-28-2021), DriveDriftDogfight86 (12-16-2021), NoHaveMSG (12-16-2021), Pete (12-16-2021), Stonehorsw (12-30-2021), timurrrr (12-16-2021)
Old 12-16-2021, 02:45 AM   #258
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
SAE correction should be applied in all dyno results. Uncorrected results or plain STD correction w/o atmospheric pressure and temperature corrections doesn't make sense. Otherwise we are comparing apples with oranges.
The Following User Says Thank You to nikitopo For This Useful Post:
Old 12-16-2021, 03:41 AM   #259
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
Well except for turbo engines as he points out, correcting turbo engines for atmospheric pressure is one really big mistake that many people do, it makes no sense.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
The Following User Says Thank You to CedN For This Useful Post:
Old 12-16-2021, 09:17 AM   #260
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I mean with a dynojet who knows if its running a load control module, the numbers can vary a lot even with the same correction factor.
Blighty is offline   Reply With Quote
Old 12-23-2021, 09:28 PM   #261
Simmons
Simmons's Avatar
Drives: 2022 BRZ
Put it on the dyno tonight.
Made 215/ 171
Here it is against a 2019 with header, exhaust and tune.
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 9 Users Say Thank You to Simmons For This Useful Post:
Code Monkey (12-23-2021), DarkSunrise (12-24-2021), DocWalt (12-26-2021), DriveDriftDogfight86 (12-27-2021), Grawlix (12-24-2021), Midnightsky (12-24-2021), Pete (12-24-2021), Stonehorsw (12-24-2021), Strat_FRS (12-24-2021)
Old 12-23-2021, 10:32 PM   #262
Lantanafrs2
Drives: 2013 frs red
Nice results. Congrats!
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Simmons (12-23-2021)
Old 12-24-2021, 05:29 PM   #263
Simmons
Simmons's Avatar
Drives: 2022 BRZ
Here is the video from the baseline dyno test.
2022 BRZ 71 STR
The Following 2 Users Say Thank You to Simmons For This Useful Post:
DriveDriftDogfight86 (12-27-2021), Midnightsky (12-24-2021)
Old 12-28-2021, 10:32 PM   #264
Pete
Pete's Avatar
Drives: 22 BRZ
Thanks @thekevinvo
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following User Says Thank You to Pete For This Useful Post:
thekevinvo (12-29-2021)
Old 12-30-2021, 01:27 AM   #265
Pete
Pete's Avatar
Drives: 22 BRZ
Thanks @Lightened
The Following 2 Users Say Thank You to Pete For This Useful Post:
PBR (12-30-2021), slimfit (12-30-2021)
Old 02-17-2022, 10:26 AM   #266
Q8D
Drives: N/A
Bumping this up with another stock dyno run
153.2kW / 238NM which equals 205whp / 175ft-lb.
Q8D is offline   Reply With Quote
The Following 2 Users Say Thank You to Q8D For This Useful Post:
Blighty (02-20-2022), LRNAD90 (02-17-2022)
Search this Thread:
Advanced Search
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 09:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 09:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 11:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 10:01 PM
