#225 |
Drives: '15 BRZ RA
Going to a 4.1 final drive ratio was a marketing decision, but I suppose the complete 4.3 rear diff should be swappable
#226 | |||
Drives: '23 BRZ
#227 |
Drives: '15 BRZ RA
Nit picking topics. Noone said about peak torque. Would you have the same 1/4-mile trap speed with a turbo car having same peak power? Can you have a simple formula to fit all the cases? Answer is NO, because with turbo you can have a much more flatter torque curve. Same about NA engines since each one has a different torque curve. We are not in the 80's or 90's where a simple formula usage might be okayish. We can have nowadays detail simulations with pretty much most of the parameters that count. But anyways, it is pretty funny going always to the very basic discussions.
#228 | |
Drives: 2018 Subaru BRZ Limited with PP
| The Following User Says Thank You to Dzmitry For This Useful Post: | Frost (11-24-2021) |
#229 |
Drives: '15 BRZ RA
Pfff. Zdan has an ACE350 header and not an ACE150 or 250, because it gives the best results under curve/ all over. It is not just about what peak power you make. So too much talking for nothing. Do you want to feel that new car is 210whp or 220whp or whatever? You are free to believe it. I am sure that something special is hiding inside this new engine
| The Following User Says Thank You to nikitopo For This Useful Post: | Dzmitry (11-24-2021) |
#230 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Power is important but that doesn't mean torque isn't. They are two sides of the same coin.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| The Following User Says Thank You to Frost For This Useful Post: | Dzmitry (11-24-2021) |
#231 | |
I actually dug up a quick example for fun. There's obviously other factors such as tires and all, but this is still a pretty decent comparison. 2008 BMW E92 M3 RWD HP: 414 TQ: 295 Weight: 3650 1/4 mile: 12.7s @ 113mph 2019 BMW M2 Comp RWD HP: 405 TQ: 406 Weight: 3560 1/4 mile: 12.4s @ 114mph You can see how closely related these come out to be, despite the M2 having a whopping 111 more lb-ft of torque, a slight weight advantage, and likely slightly better tires. |
| The Following User Says Thank You to Dzmitry For This Useful Post: | Ohio Enthusiast (11-24-2021) |
#232 | |
#233 | ||||||
Drives: '23 BRZ
Here's what you originally said that I take issue with:
Simple formula is a rule of thumb that correlates quite well for NA cars in particular. Modern turbo cars that make very near peak power over a very broad rpm range, a modified formula would work better. But hp = (trap speed/234)^3 * weight is pretty damn good for our NA cars. Gen 1: hp = (95mph/234)^3 * (2800 + 165) = 198hp Gen 2: hp = (101mph/234)^3 * (2840 + 165) = 241hp +22%! Not bad... For grins, and to demonstrate that it's not "torque that matters", let's rewind to a couple of early 90s Corvettes (L98 and LT1) that gave close to the gen1 and gen2 1/4-mile trap speeds, with roughly TWICE the torque: 1991 Corvette L98 rated at 250hp, 350 lb-ft, 3380 lb. curb weight, 96mph in the 1/4: (96mph/234)^3 * (3380 + 165) = 245hp (98% of 250hp rating) https://www.caranddriver.com/reviews...mparison-test/ 1992 Corvette LT1 rated at 300hp, 330 lb-ft, 3330 curb/3480 test weight, 102mph in the 1/4: (102mph/234)^3 * (3480) = 288hp (96% of rated) https://www.roadandtrack.com/new-car...-corvette-lt1/ There is no such simple quick/dirty approximation using TORQUE, because it is not engine torque that matters, it is POWER. Power/weight (within reason) pretty well determines performance. YES, power curve MATTERS! But "torque/weight" is meaningless and tells you nothing, whereas power/weight does. The formula myself and many others use works quite well for NA, and it wouldn't be hard to develop one for turbo cars with a much flatter power curve. Formula I'm using will tend to overestimate "peak" power for such cars. Quote:
![]() Quote:
FWIW I wouldn't have pushed the button on the header if I hadn't had a couple/few high-gravity double-IPAs...Quote:
![]() There's nothing magical in there. +20% more displacement = +20% more torque, and same peak power rpm suggests +20% power as well. And lo and behold it looks like that's about what we get. With another maybe +2% "magic". Kick-ASS! Last edited by ZDan; 11-24-2021 at 02:14 PM. |
| The Following 6 Users Say Thank You to ZDan For This Useful Post: | Baldeagle (11-27-2021), Blighty (11-24-2021), Frost (11-25-2021), Ohio Enthusiast (11-24-2021), OkieSnuffBox (12-01-2021), Spuds (11-24-2021) |
#234 | |
Drives: 2022 GR86
As long as you have a good launch and don't bog down the engine, the revs will never be in the bottom half when you're power limited (as opposed to traction limited). |
#235 | |
Drives: '15 BRZ RA
#236 |
Drives: '15 GT86 & '22 GR86
OK I think this thread has been sufficiently derailed enough. Feel free to carry on through PMs. The rest of us want to see and talk dyno numbers.
| The Following 6 Users Say Thank You to Varelco For This Useful Post: | boy_racer (12-09-2021), DocWalt (11-25-2021), DriveDriftDogfight86 (11-26-2021), groovymoonbear (11-28-2021), OkieSnuffBox (12-01-2021), x808drifter (11-28-2021) |
#237 |
Drives: 2022 BRZ Premium
#238 |
Drives: 2015 BRZ Series.Blue
| Typical Mustang Dyno Numbers? | Rockz222 | Engine, Exhaust, Transmission | 6 | 07-11-2015 09:33 PM |
| Dyno numbers | ogrowup | Engine, Exhaust, Transmission | 7 | 12-27-2014 09:04 AM |
| Average Stock Dyno Numbers? | KONVERTER | Engine, Exhaust, Transmission | 23 | 10-12-2013 11:13 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| dyno numbers seem low | stealth_fighter | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-02-2013 10:01 PM |
