Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 10-23-2021, 04:54 AM   #169
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Jianlun View Post
Screenshot from the recent HKS SpecL2 video.
Again a 1st peak at 3200 - 3300rpm (not 3700rpm in press materials) and a 2nd peak at 4600rpm. And max dip at 4300 - 4400rpm thereabouts.
Looks very similar to savage gees's numbers.
Stock looks like it gets about 156kw at the wheels, and 227nm of torque.
This would translate to 209hp and 167lb/ft =D
Blighty is offline   Reply With Quote
The Following 3 Users Say Thank You to Blighty For This Useful Post:
Dzmitry (10-27-2021), Pete (10-23-2021), Yoshoobaroo (10-23-2021)
Old 10-23-2021, 10:55 AM   #170
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Apexi's dyno in Japan
Result is 204PS which equals to 201hp. Pretty much close with what the official catalog power says in Japan (235PS / 232hp). With a correction parameter of 1.15 which is the common one for Dynapack it gives 204PS * 1.15 = 234.6PS (at the crank). After installing a full exhaust system (w/o cats) it went to 212PS or 209hp.
The Following User Says Thank You to nikitopo For This Useful Post:
Simmons (10-23-2021)
Old 10-23-2021, 03:56 PM   #171
Kona61
Kona61's Avatar
Drives: ‘22 CWP
That’s not how you calculate crank hp from wheel. If you’re assuming 15% loss which is what it seems, you divide by 0.85 not multiply by 1.15. The answer is 240 hp and it hit 246 hp after the exhaust.
Kona61 is offline   Reply With Quote
The Following 5 Users Say Thank You to Kona61 For This Useful Post:
DocWalt (10-27-2021), DriveDriftDogfight86 (11-24-2021), Jucostud (10-23-2021), Pete (10-23-2021), Yoshoobaroo (10-23-2021)
Old 10-23-2021, 06:54 PM   #172
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here is the official Dynapack definition of the 1.15 parameter:
TC Factor - allows user to enter a driveline loss factor (Transmission Correction) to add a percentage of power to the flywheel power graphs. A factor of 1.0 adds no correction factor, a factor of 1.15 would add a 15% correction factor to the flywheel numbers. Axle (rear wheel) numbers are not effected by the TC Factor box.
Source: http://www.dynapackusa.com/vehicle.htm
Old 10-23-2021, 07:13 PM   #173
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Dyno Numbers
So a 15% correction factor correlates to a ~13% drivetrain loss. Sounds reasonable. I’ve been hearing 15-20% is too conservative for 15 years, maybe 13% is closer to what modern transmissions achieve.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Kona61 (10-24-2021), nikitopo (10-24-2021)
Old 10-25-2021, 02:33 PM   #174
OkieSnuffBox
Drives: '23 BRZ Limited
And it's not just transmissions, remember in a RWD car the differential also has to turn the power 90 degrees and more friction. Aside from all the rotating mass.
Old 10-25-2021, 03:10 PM   #175
Baldeagle
Drives: VW GLI 6MT
Why is this graph is labelled “FlyWheel Power Graph.” Flywheel and Crank are the same thing. Dynos obviously measure wheel torque. Regardless of the label and actual output, the headers added some power but the torque dip still remains. While adding a few HP is always nice, my goal for a header on a Twin is not to add power but to smooth out the power curve. For me, this header did not improve the personality of the engine.
Baldeagle is offline   Reply With Quote
Old 10-25-2021, 03:16 PM   #176
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I believe it is without a tune.
The Following 3 Users Say Thank You to nikitopo For This Useful Post:
Baldeagle (10-25-2021), DocWalt (10-27-2021), Pete (10-25-2021)
Old 10-25-2021, 03:18 PM   #177
Pete
Pete's Avatar
Drives: 22 BRZ
I thought the same thing when I saw it, but I did notice that the dip is noticeably smaller after the headers. On the first gen cars the after market headers would only do so much without a tune to take advantage of the improved flow, I wonder if the same thing is happening here. Did they mention a tune before this dyno or is that just the result of the new hardware with stock tune?
EDIT: hey I just noticed that this is the first dyno that actually shows peak torque at 3700 RPM
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 10-27-2021, 10:26 AM   #178
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Correct.
Seems to gain about the same power as a first gen twin from similar mods and no tune.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
nikitopo (10-27-2021), Pete (10-27-2021)
Old 10-27-2021, 09:59 PM   #179
Jianlun
Drives: GR86 RC
From the newly updated Japan GR site. https://toyotagazooracing.com/jp/gr/...eartbeat_fast/
Anyone knows what's the SAE procedure for getting "certified" dyno numbers? Like ramp rate etc. And how that's different to the dyno runs we are familiar with. Maybe thats why the rpm peaks are all delayed by 200 to 400rpm for the peaks (3200 and 4600 for the aftmkt dynos we see vs 3700 and 5000 in the official numbers). Interesting the max dip in the official dyno is 4400rpm, almost identical to the dip for most aftmkt dynos we see.
Jianlun is offline   Reply With Quote
The Following User Says Thank You to Jianlun For This Useful Post:
Blighty (10-28-2021)
Old 11-08-2021, 02:12 PM   #180
Tracer29
Drives: 2017 Brz
I got a question about dyno numbers. Is that wheel torque or crank torque being measure?Name:  Screenshot_20210826-212105_Gallery.jpg
Sent from my SM-G781W using Tapatalk
Tracer29 is offline   Reply With Quote
Old 11-08-2021, 02:27 PM   #181
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
WHP is Wheel Horse Power. That is a rolling dyno for wheel hp numbers. ^^^
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 11-08-2021, 02:29 PM   #182
Tracer29
Drives: 2017 Brz
I get the whp but is the torque also to the wheel?
Search this Thread:
Advanced Search
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 09:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 09:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 11:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 10:01 PM
