Oil Cooler for a DD with track days?
So I have begun getting into tracking my car a few times a year and have come across many threads saying that if you track your car at all, you should get an oil cooler for extra insurance. After doing a little bit more research, I found that an oil cooler may not be the best idea on a DD car where most of the trips might not get the oil up to temperature with an oil cooler. I came across a pretty good deal on a Jackson racing oil cooler near me and wanted to know what you guys think. Do you think I should pick the cooler up because I need it for tracking and it would be fine to have daily driving, or would it be a bad idea because my oil might not get up to proper temps when daily driving it and maybe I should get a different solution for when I take it to the track? Everything is stock under the hood besides UEL headers.
Drives: '23 BRZ
You don't need an oil cooler. You should run 30 or 40wt full synth oil during track season tho...
| The Following User Says Thank You to ZDan For This Useful Post: | Dububster (08-21-2021) |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Use your data to drive the decision. What does your oil temp look like on track?
Modern oils have no problem protecting under optimal temperature. They DO however lose viscosity (and pressure) rapidly once over temp. It’s the pressure drop that is the problem for the Fa-20s. Get the JR kit. The included thermostatic plate will keep it from being too cold for daily driving, but will protect you from severe pressure drops on track. Sent from my iPhone using Tapatalk Last edited by BlueWhelan; 08-22-2021 at 03:06 AM. |
#5 | |
I have the Jackson Racing kit on my daily driver. I commonly see 150-170 in my daily commute. This is totally fine. Modern synthetic motor oils are designed to flow well even at temperatures much lower then that. You’re not going to damage your engine by failing to get oil up to 180F while daily driving. If that was the case, everyone who drives their car for 60 seconds to the grocery store would be spinning bearings left and right.
Now, I will say that you generally should avoid redlining the thing while the engine/oil is cold, but that’s probably more to do with engine tolerances at operating temperature rather than oil viscosity. Anyone who blows an engine with cold oil was either caning it without a warmup, or something else was going on. Sent from my iPhone using Tapatalk |
#7 | |
#8 | |
Drives: '23 BRZ
With no cooler, oil temp in my car reliably goes to just over 270F at the track and never climbs from there, even in 95F ambient temps. That's not a problem at all for good synthetic. I run 30wt and change every couple/three events and don't worry about it... Last edited by ZDan; 08-22-2021 at 09:14 AM. |
#9 | ||
Drives: '23 BRZ
https://www.ft86club.com/forums/showthread.php?t=91820 |
#10 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | timurrrr (08-24-2021) |
#11 | |
Drives: 2018 BRZ
Does anyone have oil temp numbers of a stock Twin without an oil cooler on the road? |
#12 |
Drives: Some rust bucket
don't forget you're adding an additional point of failure with an aftermarket cooler. how often do you go to the track? just keep that in mind.
| The Following 3 Users Say Thank You to ayau For This Useful Post: |
#13 | |
Drives: '23 BRZ
Mine gets to ~190F within 5-10 minutes even in winter toodling around town at low speed/low-rpm. Higher that on the highway at 75+. One reason I don't get an aftermarket cooler is to ensure oil gets up to temp quickly in the cold months. |
| The Following User Says Thank You to ZDan For This Useful Post: | Ohio Enthusiast (08-22-2021) |
#14 |
Add some OEM crash bolts and max out the front negative camber if you haven't done so already. Much less risk than adding an aftermarket cooler. It sounds like you're just getting started, so I would avoid messing with something as important as engine oil system unless you know you need one. You'll know when you need one.
| The Following 4 Users Say Thank You to ayau For This Useful Post: |
| Track Days With GPS Track Time! | Guff | Great Lakes | 2 | 03-11-2016 11:47 PM |
| Oct Track Days | Lunatic | Tracking / Autocross / HPDE / Drifting | 0 | 09-23-2014 12:46 AM |
| Scion FRS HKS Oil Cooler Kit - A must for track days!!! TAP Auto | TAP Auto Parts | Engine, Exhaust, Bolt-Ons | 1 | 06-05-2013 03:40 AM |
| HKS Oil Cooler Kit - A must for track days - FT86 Club Private Sale $928 delivered!! | TAP Auto Parts | Engine, Exhaust, Bolt-Ons | 5 | 11-30-2012 11:01 PM |
