Old 08-06-2021, 01:30 PM   #43
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by FR-S2GT86 View Post
@ZDan, has your car by chance been included in the new fuel pump recall? Just a thought.
No, recall is for some 2018/2019, mine is a '17
ZDan is online now   Reply With Quote
Old 08-06-2021, 03:24 PM   #44
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by ZDan View Post
How difficult is that to implement? Has anyone documented this? If I wing it I *will* f it up :O
Will it fit under stock seats? Is street car...
Looking at a picture of our fuel tank, there are two fuel basket openings, one on each side. May be able to run a second fuel basket with pump on the passenger side, but plumb the outlet to dump into the fuel basket on the driver side and use that to feed the car.
Old 08-06-2021, 05:30 PM   #45
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Before going through all of that, @ZDan might want to simply replace his fuel pump and filter to eliminate that as a possible cause. These pumps aren't that expensive and they are relatively easy to replace.
Have we gotten any logs on the fuel pressure and/or fuel pump motor current draw during a fuel starvation incedent yet? That would help to determine the cause.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 08-06-2021, 05:43 PM   #46
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't know if there is a PID for pump current, it may require some duct tape, a camera, and a multimeter to get those.
Old 08-06-2021, 06:39 PM   #47
ML
ML's Avatar
Drives: 13 White MT FR-S
lol Like I said above 350z community has solved this issue long ago.
https://www.z1motorsports.com/z1-pro...it-p-9558.html
Old 08-11-2021, 02:41 AM   #48
e21jason
Drives: GT86 TRD Cup
Radium engineering do a replacement pump assembly and you can run 2, one each side of the tank
http://www.radiumauto.com/Fuel-Hange...mps-P2108.aspx
This is what the HPacademy guys run in there endurance gt86
e21jason is offline   Reply With Quote
Old 08-11-2021, 12:26 PM   #49
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They are also running a surge tank with two additional pumps to feed a V8. The pump hanger with one pump is 670/ea. An OE fuel pump is 377 from subaru, and around 150-180 for a parts store for an aftermarket. For someone like me it may be worth exploring running two OE fuel baskets and running them together. Otherwise I will just keep a full tank.
Old 08-11-2021, 11:39 PM   #50
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm not convinced that's a picture of a plastic part... Looks like a slightly sloppy bit of cnc work there...
The Following User Says Thank You to cjd For This Useful Post:
ZDan (08-13-2021)
Old 08-12-2021, 02:06 AM   #51
ZDan
ZDan's Avatar
Drives: '23 BRZ
The part I received is most definitely 3d printed plastic...
[edit]HA! Wrong, it's black painted or powdercoated aluminum. I removed it as at best it didn't help my issue (same starvation after extended left at Palmer) and at worst might have caused additional issues (starvation after long straight and *right*-hander at Thompson, at ~15/16 tank!)
cjd (08-13-2021)
Old 08-13-2021, 04:13 PM   #52
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'll be damned, I just removed it and the part is indeed cnc machined aluminum painted or powder-coated black, and *not* 3d printed plastic!
My initial impression of the part based on it being one piece (rather than previous version which look to have had a pressed in pin), gloss shiny black, and being practically weightless (this is due to it being massively hogged-out on the backside). I installed it thinking it was plastic, being careful not to snap off the pivot pins! But yeah, machined aluminum...
cjd (08-13-2021)
Search this Thread:
Advanced Search
DIY : Draining the gas tank - Methods to empty fuel tank Mermoz DIY (Do-It-Yourself) Guides 8 05-17-2023 06:26 PM
Fuel Starvation? Lunatic Tracking / Autocross / HPDE / Drifting 37 03-29-2018 12:47 AM
How to fix fuel starvation on left hand turns - Verus Fuel Door FT-86 SpeedFactory Engine, Exhaust, Transmission 3 08-21-2017 04:22 PM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 12:19 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 11:14 AM
