Old 08-21-2021, 06:26 PM   #29
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by J52 View Post
I could get used to it but I wish there was a better solution, but at least I'm getting closer to a fix. Wish I could like shorten the CMC rod just a little so I can have a better clutch pedal position but still have the benefits of the press being longer.
This is precisely what you seek. https://www.ft86club.com/forums/showthread.php?t=77390
edit: ...assuming everything else is working properly.
Old 09-23-2021, 02:13 PM   #30
Rob803
Rob803's Avatar
Drives: 2016 Scion Frs
Would you recommend this mod for someone with an aftermarket clutch or just factory? I been having the exact same issues in this thread but with a competition stage 3 clutch, pressure plate, and verus forged clutch fork. Also im turbo at 7psi (277whp) if that makes a difference here.
Rob803 is offline   Reply With Quote
Old 09-23-2021, 02:40 PM   #31
Ultramaroon
fabulous
Just realize that there is a tradeoff. A narrower engagement arc requires greater pedal force - about 17% IIRC. The change is inexpensive and easily reversed.
clutch, shifting, transmission
Search this Thread:
Advanced Search
Trouble shifting into gear at a stop Demolitionist Issues | Warranty | Recalls / TSB 4 09-25-2019 03:48 PM
Issues Shifting Into Gear From Stop bryan86tx Issues | Warranty | Recalls / TSB 12 02-27-2019 03:26 AM
Can't get into any gear from a stop once car is warmed up Pneub Engine, Exhaust, Transmission 34 04-23-2014 12:50 PM
Can't get into any gear from a stop once car is warmed up Pneub Issues | Warranty | Recalls / TSB 5 04-04-2014 03:32 AM
Coasting to a stop in higher gear subiestyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-28-2014 06:31 PM
