#15 |
Barred
Drives: My18 wrxsti My19 brzts
Had my fuel pump recall done. All good. I took the car to the track and proceeded as normal. Bigger sticky rubber, new coil overs and a new pb. No more fuel surge/starvation. It loves the long left hand sequence now.
Wait until my Flex capacitor hits 88
#16 |
Drives: '23 BRZ
I have since discovered that it wasn't fuel starvation! I installed a header and got a custom tune, which cut power above some low rpm when oil temp reached 274F! It just so happened that at NHMS and Palmer it *always* happened ~5 laps in just after the extended left-hander! Tuner bumped the cutoff oil temp up to 285F and no problemo after that...
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#17 |
Barred
Yeah its strange that it went away. Nothing else was changed and its summer here so definitely not a temperature issue. Maybe I was just soft cocking that part of the track? but my lap times showed otherwise 1/2 a sec quicker.
#18 | |
Drives: '23 BRZ
I have had *real* fuel starvation, a few years back at Palmer. Was running ~3/8 tank and 1st timed lap in my time trial lost power coming out of Turn 2. Luckily for me, someone went off (he was fine!) and the session was black-flagged, so I was able to duck into the pits and get fuel ![]() Since then I just make sure I have >1/2 tank which I need to for time trials anyway to meet weight. |
#19 | |
Barred
Lately they have been throwing some professional cars and drivers out near me. Great fun seeing them have to use the straights to pass and slowly meander away through the rest.
| The Following User Says Thank You to gen3v8 For This Useful Post: | ZDan (12-17-2021) |
#20 |
fabulous
Leaf switch with a slug glued to it. Mount it so the pump only runs on left handers. Or maybe arduino and accelerometer to filter out the bumps. Do we know how to get that data from the can bus?
#21 | |
Drives: Crapcan
Asking for uh............a friend.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | DocWalt (12-21-2021), Ultramaroon (12-20-2021) |
#22 | |
fabulous
edit: A couple unknowns here. I can't figure out what the DI signal is between ECU and FPC. If the impedance of the FPC input is too low, running two in parallel would drag down the signal from the ECU. It's just a few steps of DC voltages to set the duty cycle of the pump. I'm liking the idea of a pump in the right side dumping fuel into the cup during left-handers. It's what I would try.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | brianbui23 (01-28-2022), NoHaveMSG (12-20-2021) |
#23 |
Drives: 2015 Subaru BRZ Limited DGM
Jumping on this thread because I also get fuel starvation at the NHMS oval under 1/2 a tank. I'm on 225 Falken Azenis RE660s (that is, less grip than ZDan). Stock engine/header/tune, but Walbro 485 pump WITH the Verus door. And yes it's annoying because to keep over 1/2 tank, I run out of fuel in my 5gal jugs and have to pay gouging track pump prices.
The second fuel pump seems a little over my head, and I've not seen a really clear tutorial. Ditto a surge tank. Mixed results reported from Hydromats. Can anyone help get me pointed in a good direction here? Thanks. |
#24 | |
Drives: Crapcan
https://www.z1motorsports.com/z1-pro...it-p-9558.html https://www.z1motorsports.com/z1-pro...it-p-9558.html
#25 | |
EDIT: any reason I couldn't use a pump like this on the right side: https://www.pegasusautoracing.com/pr...sp?RecID=30036 Last edited by gcranston; 01-13-2022 at 11:39 PM. Reason: 2nd pump question |
#26 | |
Drives: Crapcan
I elected to buy another used OE fuel basket off ebay, I think I paid 65 bucks. I was going to check out the in tank senders as there is one on both sides, I bet they read in the same range and I may be able to use the sender on the second fuel basket in place of the one on the right side unit. I also plan on driving the pump with a cheap PWM DC motor controller since it probably doesn't need run at 100% all the time. Something like this. https://www.amazon.com/RioRand-7-80V...NsaWNrPXRydWU=
#27 | |
I emailed a couple boneyards last night for the whole pump & sender assembly. Swapping that in and just having both pumps run together seems easiest to me. The cheap facet pump from Pegasus was attractive if I had to cobble something together, but I'd rather just drop in the whole assembly. I'm ok with the risk of burning out the 2nd pump faster; I'll just replace it if/when that happens. Thanks! EDIT: thinking through it a little more though... you'd use that motor controller just to turn on and 'throttle' the second pump, what, track by track? It might make sense for my use case to at least have a switch so I only enable the second pump at the track, or even tracks where I have a problem, and not run it on the road. Last edited by gcranston; 01-14-2022 at 12:44 PM. Reason: 2nd thoughts... |
#28 | |
Drives: Crapcan
The factory fuel pump controller changes pump speed based on demand. I looked at possibly running a second factory pump controller and tying it into the signal from the ECU to run both pumps, but as looking at it in the above posts, not sure it will play nice so decided to try something simpler.
| Fuel starvation, verus flap? | ZDan | Tracking / Autocross / HPDE / Drifting | 9 | 05-19-2021 01:47 PM |
| Fuel Starvation? | Lunatic | Tracking / Autocross / HPDE / Drifting | 37 | 03-29-2018 12:47 AM |
| How to fix fuel starvation on left hand turns - Verus Fuel Door | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 3 | 08-21-2017 04:22 PM |
| Fuel Starvation issues? YAY OR NAY? | track_warrior | Tracking / Autocross / HPDE / Drifting | 23 | 10-22-2013 12:19 PM |
| Fuel Starvation | feldy | Tracking / Autocross / HPDE / Drifting | 1 | 06-09-2012 11:14 AM |
