Old 06-15-2022, 11:37 PM   #15
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
Originally Posted by RedReplicant View Post
Resetting the fault codes also resets your monitors, so yeah, back to square one.
Much appreciated! I’ll give DEQ a try again tomorrow after another 50 or so miles
Skyehigh55 is offline   Reply With Quote
Old 06-16-2022, 07:58 PM   #16
Skyehigh55
My CEL for P0420 just came on as I was driving home from work this morning going through drive cycle to get all systems ready. Would I fail just because of this fault code whereas all other systems should be ready? Or do I have to clear the codes again, drive a proper drive cycle then get DEQ tested before the P0420 CEL gets thrown for being catless? I’m so confused here if I can pass or not since I believe I drove enough for all systems ready yet the timing perfectly triggers CEL for P0420
Old 06-16-2022, 08:57 PM   #17
RedReplicant
Drives: None
That is correct, CEL / set codes means no emissions pass.
The info from Oregon (https://www.oregon.gov/deq/filterdocs/driversguide.pdf) indicates that you can have one readiness monitor not set and still pass, so if you're able to time it right where your catalyst is the only monitor not ready / code not set you'd be able to pass.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Skyehigh55 (06-16-2022)
Old 06-23-2022, 06:51 PM   #18
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
I think you'll either have to put on the stock header or adjust the OFT tune to turn off the EVAP disabling. You can get away with a single unready code but not two, I've ran through our DEQ a few times with a tune and it's no problem.
sirbobbinhood is offline   Reply With Quote
Old 06-23-2022, 09:19 PM   #19
steve99
if you just want to pass emmissions try just disabling P0420 on a stock tune
Old 06-23-2022, 09:21 PM   #20
steve99
see post here if you just need P0420 removed on a stock K00c rom
https://www.ft86club.com/forums/show...5&postcount=19
Old 06-25-2022, 04:10 AM   #21
Skyehigh55
That’s why my first try is to go back on stock tune, run my drive cycle until complete and hope the CEL doesn’t go on, then get it tested. By then, all systems besides the primary cat should be okay and ready. I’m waiting for an O2 spacer to arrive to see if my theory checks out. If not, I will need a revised 17’ tune with EVAP system enabled so I only have cat unready flagged. Steve99 reached out to me and am trying to sort this out in the coming week. Thank you all for the help!
Old 08-06-2022, 02:35 PM   #22
Skyehigh55
I used a stock rom with P0420 disabled from Steve99 and passed! Thank you guys for all the help! Now I’m looking forward to trying E85
The Following User Says Thank You to Skyehigh55 For This Useful Post:
Aztec (08-09-2022)
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 03:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 04:43 PM
Innovate Stage 1 Supercharger with stage 2 accessories azynneo Engine, Exhaust, Bolt-Ons 3 08-30-2016 01:32 AM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 10:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 11:16 PM
