86WORX
Old 06-30-2021, 08:20 PM   #15
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by Nfsundrgrnd View Post
That actually makes a lot of sense! Is it an easy thing to replace or does the trans need to come out? Also is there an inspection window/hole on the tranny that I could take a look in? Wondering if I could see the damage from there.
People have fed borescopes through the vent port at the bottom left of the bell housing. That would get you there for sure. Might be able to pull the dust boot off of the top of the fork and look down that way. Otherwise, trans needs to come out.
Nfsundrgrnd (06-30-2021)
Old 06-30-2021, 10:37 PM   #16
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
Alright, I'll probably end up taking a look soon. I'll update back if I find the problem.
Nfsundrgrnd is offline   Reply With Quote
Old 07-01-2021, 12:08 AM   #17
itschris
Drives: '14
I spent a good hour looking for a disturbing image of a failed clutch fork that looked like it had worn through the center pivot and had several radial fatigue failure cracks.
Someone posted it last week-ish and, unfortunately, I blew past it without subscribing. I strongly supect that it's relevant here.
This one?
https://www.ft86club.com/forums/show...29#post3444429
Mine was pretty similar, only a couple cracks but they were a bit larger and let the fork bend. I put the Verus one in. Feels reminiscent of old BMW clutches now.
Always learning.
itschris is offline   Reply With Quote
The Following User Says Thank You to itschris For This Useful Post:
Ultramaroon (07-01-2021)
Old 07-01-2021, 01:15 AM   #18
Ultramaroon
fabulous
Originally Posted by itschris View Post
This one?
Yes! Phew! Was killing me. Thanks.
Old 07-07-2021, 11:23 AM   #19
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
since you only have 3,500 miles, i'd take it to dealer
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
Goingnowherefast (07-07-2021), Ultramaroon (07-07-2021)
click, clutch, noise, pedal, tick
Search this Thread:
Advanced Search
Clicking noise while Driving stops when Clutch is pressed Inteze Engine, Exhaust, Transmission 12 04-09-2020 02:07 PM
Clicking noise from clutch when depressed/released? BaeK Issues | Warranty | Recalls / TSB 29 02-10-2020 02:48 PM
Clutch Pedal "Clicking" Noise on new BRZ Shizuka Engine, Exhaust, Transmission 6 05-31-2019 02:57 PM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-27-2015 12:19 AM
LOUD TICK-TICK-TICK sound on right hand side PoRco Issues | Warranty | Recalls / TSB 16 07-28-2014 01:55 PM
