#57 | ||
Drives: '23 BRZ
For me, I take it as roughly "a lot stiffer"... I should mention that mid-corner understeer was reduced with the stiffer swaybars, but I'd still like a bit less and for the car to be more pointable. Just don't know how far I can go redistributing front/rear roll stiffness before unloading of the inside rear becomes an issue for the Torsen. Especially given the car's unfortunate nose-heaviness... |
#58 | ||
Drives: 2022 GR86
Gotcha
If my math and parameters are right, your car has higher front/rear roll stiffness ratio than any stock BRZ/86/FR-S, making it naturally pushy. To match the front/real roll stiffness ratio of the '13–'16 BRZ you'd need a bar that's 250% stiffer than the 14 mm OEM. You can probably go even stiffer, maybe up to 300% stiffer than OEM. Quote:
Depending on your goals and the budget it might be worth investing into a clutch-type LSD to address this, to "unlock" more possibilities to achieve the desired balance in the first half of the corner. |
#59 | |||
Drives: '23 BRZ
No stock factory BRZ/86/FR-S had -3.5 front camber, that does make a bit of difference in "pushiness"... Quote:
I might swap the stock front sway bar back in. Or not... Car is quite driveable and capable of decent lap times as it is. Quote:
Ultimately I'd like to cut out a section of the car between the rear wheels and the doors to fix the weight distribution. Not exactly a practical solution tho! |
#60 | ||||
Drives: 2022 GR86
I'm calculating only the stiffness of the suspension, not factoring in the effects of alignment, camber curves, etc. They can be accounted for separately, but I'm not doing that right now. Quote:
More loose than any suspension setup I currently have in my spreadsheet. I suggest trying a ~+100% over stock front bar instead, such as Perrin 19 mm on the Hard setting, or Whiteline 20 mm on Soft, or Perrin 22 mm on Soft (these three provided options are in the softer-to-stiffer order). Quote:
#61 | |
Drives: '15 BRZ RA
#62 | ||
Drives: '23 BRZ
For sure there are day to day variations, but it definitely looks like on Saturday I was doing a better job carrying speed into turns 3, 6, and 9. See the bottom plot for my best lap on 245-square from Saturday (green) and from Sunday (purple). Actually, looks like time lost in 9 on Sunday was immediately gained back so call that a wash. Big differences are Turn 3 and Turn 6 where, lost 0.25s in each of those. It is a subtle art and consistency is not one of my strong points.... Last edited by ZDan; 11-18-2021 at 10:12 AM. |
| goin to Watkins Glen with rear toe-OUT :D | ZDan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-21-2020 04:18 PM |
| Hp vs stagger | Howardwei | Tracking / Autocross / HPDE / Drifting | 1 | 04-06-2014 03:39 PM |
| EVO goin EVo | tahdizzle | Other Vehicles & General Automotive Discussions | 1 | 04-01-2014 04:32 PM |
| 17" stagger? [8.5 / 9.5]? | ZionsWrath | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-16-2014 07:42 PM |
| any meets goin on near ucsd? | Jeong | Southern California | 5 | 11-29-2012 12:07 AM |
