#29 | |
Drives: '23 BRZ
See how it goes! If it's still an issue I might get those Tarmac springs. Or get coilovers... |
#30 |
I also think the fix would be to add ride height and roll stiffness.
If you haven't tried adjusting your line or driving yet, I would try to get the car rotated more on corner entry and go for a point-and-shoot approach. Do you have a video clip of this track? Last edited by SCFD; 05-20-2021 at 11:30 AM. |
| The Following User Says Thank You to SCFD For This Useful Post: | ZDan (05-20-2021) |
#31 |
Drives: '23 BRZ
OK, I changed my tire order from 255/235 reverse-staggered to 235-square.
Thanks to all who contributed their $0.02! I decided that it would be a better approach to increase roll stiffness than to go with wider fronts. 245/40-17 A052s aren't available, so going with 235/45-17 and using the half-classification-point saved to partly offset the 1-point added with aftermarket sway bars. Might need a few pounds of ballast, but can use that to slightly improve weight distribution... Thinking about getting Eibach sway bars, if anyone has opinions feel free to share here or in the separate thread I made. Specifically interested about Eibach sways compatibility with Bilstein B8, -1.25" ride height (on stock-diameter springs), and maxed out front camber at -3.9 degrees (via camber plates). Thanks again, all! |
| The Following User Says Thank You to ZDan For This Useful Post: | SCFD (05-20-2021) |
#32 |
Drives: 2017 Toyota 86 (860 SE)
I don't even track, but this thread was educational. Thanks!
#33 | |
Drives: '13 Whiteout
#34 | |
Drives: Crapcan
#35 |
#36 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
So what was the outcome?
Is this NASA or SCCA TT?
#37 |
Drives: '23 BRZ
Good result at Palmer (CW), where midcorner understeer can be an issue. Much improved with the Eibach sways (front at softer setting, rear stiffer setting)! Better balance through 4, better drive onto the straight between 4 and 2. Won TT by healthy margin, 0.78 sec. Won next event at Thompson as well. Competition bought new Hoosiers for the next event at Palmer (CCW this time), and killed me. But I got him back at Watkins Glen. I'm up by a couple of points going into New Hampshire South Oval this weekend.
This is with COMSCC, regional club here in New England. https://www.comscc.org/events/results/ |
#38 |
Drives: 2022 GR86
#39 | |
Drives: '23 BRZ
I ran New Hampshire Motor Speedway South Oval this past weekend, I ran the newer 245/40s all around for Saturday's sessions. 1st practice Sunday was on 245/40 fronts and 235/45 rears, I didn't change fronts due to front right lug nuts being kinda "stiff" and not freely spinning off, so I just torqued them back down with the 245s up front. I set similar times as Saturday (1:14.3) despite errors and the track being slower (i.e. known references were going ~1/2-sec to 1-sec slower. The gearing was just way better with the tall 235/45s, saved me an upshift before entering the South Oval, before Turn 3, and before Turn 11. I did 2nd practice on 245/40s all around and did a 1:14.77, so I went back to 235/45-17 rears with 245/40-17 fronts for the TT. Made mistakes and didn't go faster but 1:14.79 was good enough to win my class by a lot and barely get the COMSCC T50 lap record
#40 |
Drives: 2022 GR86
Now I'm even more confused
#41 |
Drives: '23 BRZ
Basically, I ran reverse stagger but not necessarily because I wanted to. I was paranoid about stripping lug nuts out so I left the 245s on front and tried the 235/45s in back, and that was clearly the faster setup at NHMS South Oval due primarily to better gearing, but also the more worn 235s at the back of the car felt more stable in the oval turn. I'm sure I would have done similar times with 235s all around.
| The Following User Says Thank You to ZDan For This Useful Post: | timurrrr (10-11-2021) |
#42 | |
Drives: '13 FRS
Dan, I don’t think we’ve formally met, but I was the guy on a crutch standing there with Roe as you came up on the scales. Blistering times you set that day, I’ll take any advice you have setting up my FRS for COM next season. New driver, long time wrench, so I have a lot to learn. Do you think the larger rear circumference matters to the ABS? I assume you have VSC disabled, but it would seem the opposite scenario of what would trigger traction control. Sent from my iPhone using Tapatalk |
| goin to Watkins Glen with rear toe-OUT :D | ZDan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-21-2020 04:18 PM |
| Hp vs stagger | Howardwei | Tracking / Autocross / HPDE / Drifting | 1 | 04-06-2014 03:39 PM |
| EVO goin EVo | tahdizzle | Other Vehicles & General Automotive Discussions | 1 | 04-01-2014 04:32 PM |
| 17" stagger? [8.5 / 9.5]? | ZionsWrath | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-16-2014 07:42 PM |
| any meets goin on near ucsd? | Jeong | Southern California | 5 | 11-29-2012 12:07 AM |
