Old 05-09-2021, 11:38 PM   #15
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by ZDan View Post
TL/DR, it's still happenin and it aint' fuel starvation (I don't think)
How's the dipstick reading? What's the oil temp?
Old 05-10-2021, 12:09 AM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Plenty of oil, if anything too much, it was reading low so I added some but I think I misread so now maybe it's 1/2-quart HIGH.
Oil and coolant temps same as always, nothing untoward there.
Ultramaroon (05-10-2021)
Old 05-10-2021, 12:13 AM   #17
jflogerzi
jflogerzi's Avatar
Get the log to the tuner. They would be able to tell you. No sense us guessing
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Ultramaroon (05-10-2021), ZDan (05-10-2021)
Old 05-10-2021, 02:17 AM   #18
ZionsWrath
Thanks
ZionsWrath's Avatar
I money shifted mine and it ran fine. But two years later engine started knocking. Did track days in between never over revved it again. Not sure if related but probably was, car had 56k miles with a few dozen track events.
Old 05-10-2021, 04:09 AM   #19
You can't starve a full tank but you can starve at 7/8 tank under the right conditions
ZDan (05-10-2021)
Old 05-10-2021, 03:26 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
Hmm, the only stints when this happened were ones where I didn't start with a full tank...
New Hampshire Motor Speedway turn 6 is a banked left-hander which blends into turn7, combined turn is >180 degrees. But I've never had fuel starvation here before, even on Hoosier A7s last year. I was running Nankang CR-1s yesterday.
Old 05-10-2021, 06:30 PM   #21
Interesting. How's steering angle different with the two cars? Are you steering more on the Hoosiers?
Best practice may be to run a full tank or a secondary pickup.
Old 05-10-2021, 06:41 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
Same car, same setup, I'd guess I may be cranking in more steering angle for max grip with the Nankangs.
Full tank works as I need a full tank for my min. weight for time trial anyway.
Hopeful that it is indeed fuel starvation, I sent data files to Zach, looking forward to see what he thinks.
Old 05-10-2021, 07:38 PM   #23
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I don't think it's fuel starvation if it correlated with an over rev. I wonder if there's any trouble codes that have not resulted in a CEL that can be seen via techstream.
SCCA T4 - FRS
Old 05-10-2021, 07:44 PM   #24
jflogerzi
jflogerzi's Avatar
ecutek would should show these as well which he has access too.
Old 05-10-2021, 08:25 PM   #25
rice_classic
I'm aware - it was more focused on seeing if there's anything he can get insight to prior to waiting for a tuner to review things.
SCCA T4 - FRS
Old 05-11-2021, 07:56 AM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
Tuner sez "100% typical fuel starvation". Whew... Honestly I've never felt like I had more grip railing around NHMS turn 6 than on the CR-1s, I'm liking these tires a lot so far. Still, fuel starvation at 7/8 tank?! I might hafta do something about that before Palmer if only to avoid paying for at-the-track fuel for every session!
The Following 2 Users Say Thank You to ZDan For This Useful Post:
DarkSunrise (05-11-2021), jflogerzi (05-11-2021)
Old 05-11-2021, 08:09 AM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
The issue also correlates with not starting session with a full tank. But yeah, the 1st time it happened was only a few laps after the overrev. Engine sounded extremely valve-noisy to me but then I listened to my bud's same-year 86 and it makes the same noises (mostly injector noises I think). We have similar setups, and our acceleration plots fell right on top of each other so my engine is performing normally otherwise.
Still, I was thinking that maybe VVT mechanism(s) might have been damaged and might quit "VVTing" after a few laps, but why would it reliably fail at exactly the same spot on the track every time? @CSG Mike's post about starvation "under the right conditions" is hugely encouraging. Heavily banked 180-degree left-hand NHMS Turn 6, with a little flat table top I use at track-out, while continuing left into Turn 7, on tires that honestly feel faster and more confidence-inspiring here than even 8-cycle Hoosiers I was on last fall, might all add up to "the right conditions".
jflogerzi (05-11-2021), SCFD (05-12-2021)
Old 05-11-2021, 12:04 PM   #28
jflogerzi
jflogerzi's Avatar
Your post made feel better about my money shift lolz
Search this Thread:
Advanced Search
Possible overrev on the track; does ECU store max lifetime RPM reached? SmoothIsSlow Engine, Exhaust, Transmission 21 07-22-2021 07:04 PM
Need help about the mechanical coverage! hoangjm Scion FR-S / Toyota 86 GT86 General Forum 29 04-11-2019 03:51 AM
frs oversteer in brz mechanical? swpbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-18-2014 10:48 PM
Overall mechanical satisfaction? Tman08 Issues | Warranty | Recalls / TSB 15 08-26-2013 06:28 PM
