#71 | |
fabulous
If you lift the reverse lockout foot you can distinctly feel the width of the first and second gear gates. The lockout foot rides against a shoulder on the top plate. That's why alignment is so important. Be gentle, especially with the engine off. Expect the gear selector hubs to clash with the gears. Soft bronze balk rings are delicate.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | T_Squadrito (05-11-2021) |
#72 |
Drives: White 2014 brz
I am gonna dig up this old thread real fast to say, I havn't gotten around to the slave cylinder change yet, however, I adjusted the clutch pedal to get rid of some of the dead space and it was the best thing I ever did. That alone made an absolutely HUGE impact on the feeling of the car. I pushed it really far so it took longer than the typical 10 minutes. I got it about 2mm below the brake pedal and it was grinding a little if I pushed first really hard so I dialed it back a turn and a half and it seems to be grabbing fine now. Best thing I have done so far. I have put a bit of work into the car since I started this thread and none of it comes close to the 45 minutes to adjust, test drive, and do an additional adjustment and unlike a lot of the other work it was no added cost. Remember how I said I couldnt get a rolling start without gas because of the texture of the ground? yeah thats no longer true. I can get a rolling start just fine. My clutch control and shifting is instantly about a million times better. I cant wait to see what happens when I get the new slave cylinder in. I know it's an easy swap but I want to do it when I have a friend to help out but its been pretty dead lately so it's on the backburner still for just a little longer.
#73 | |
fabulous
#74 |
After adjusting it after the test drive I have about maybe 2cm before grabbing. No problems getting into gear at all even the first time around. It was just on hard take offs (I put the car through its paces during the test drive to be safe and im glad I did because I probably would have missed it otherwise.) I just dialed back the bolt on the master about 1 and 3/4 turns and it put it back just about shy of flush with the break pedal and no issues on the second test drive. I was definitely aggressive with the first one. I did the standard first neutral reverse and slow shift test while I was in our parking lot and had no issues so until the test drive it seemed fine. Like I said, glad I worked it a bit during the test drive. just a simple 1 3/4 correction fixed that right up and it is much much much easier to drive now and I am not lifting my leg til it hits the steering column to shift anymore which is great (I have the torso of someone 4'6" but the legs and arms of someone 6'. Questions are asked when my 5'9" self can reach things on the top shelf that people taller than me cant lol.
| The Following User Says Thank You to T_Squadrito For This Useful Post: | Ultramaroon (05-31-2021) |
#75 | |
fabulous
2 cm is excellent.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | churchx (06-01-2021), T_Squadrito (05-31-2021) |
#76 |
Haha. I may actually look into it when I do my wheel. Mine is pealing (guessing the last owner left it in the sun a lot. Car did come from a southern state so who knows). It's weird because my legs are long and even with longer arms if I sit where my legs are comfortable my arms are at a weird length and if I sit where my arms are comfortable then my legs get all crammed in there. The adjustment helped a LOT with that so at least now it's not as awkward. Comparatively, it's even good. I do suspect a steering column extension might be useful.
#77 |
Drives: 2014 GT86
If you want to retain stock airbag, then 949 Racing 50mm steering spacer is good option. Worth getting control stalks extensions with it though, as with steering wheel being offset you cannot easily manipulate them as is w/o taking hands off wheel anymore.
| The Following User Says Thank You to churchx For This Useful Post: | T_Squadrito (06-01-2021) |
#78 | |
| OFT - Noob Question | jRuN | Software Tuning | 4 | 08-21-2018 08:55 AM |
| Noob question about OFT | nyfries | Software Tuning | 4 | 12-09-2014 01:07 AM |
| noob question here about f.I.... | zimzum | Forced Induction | 7 | 03-06-2014 05:24 AM |
| Noob question | dro | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 07-05-2013 10:33 AM |
| Noob Question.. | wWaldo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-21-2013 09:04 PM |
