#29 | |||||
Drives: '23 BRZ
![]() Do you have dyno plots to share? Quote:
Really though, ideally I'd just dyno before tune and then dyno again after. Like I said, I'm *curious*. Quote:
ACE header is still in my kitchen and not on the car, I got SV650 running yesterday and went for ride, today it's raining, I'm outta town next weekend and track event is weekend following. Unless I get somebody to install it for me it might have to wait until after 1st event (doh!) |
| The Following User Says Thank You to ZDan For This Useful Post: | Dzmitry (04-25-2021) |
#30 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
The easy button is just getting the ACE350 tune from Delicious Tuning (https://www.delicioustuning.com/Stage_2_BRZ_FRS_86). They do revisions based on your datalogs. These ECU's are pretty legit though, so it doesn't take much time and there's barely anything to be gained with a full dyno tune.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
| The Following User Says Thank You to Goingnowherefast For This Useful Post: | ZDan (04-25-2021) |
#31 | |
Drives: 2018 Subaru BRZ Limited with PP
I believe ACE does a great job of filling in the whole power band and doing it all the way up to the peak. Not sure what the issue was in that example thread. I do have my dyno to show you below, but I do not have a stock one or any other to compare it. This is with a K&N filter, ACE headers and overpipe, and CSG Touring86 cat-back. This dyno was done on a colder day and in 4th gear (due to a smaller fan up front and the risk of more heat in 5th gear). Prior to the dyno, I was tuned by Xero-Limit with a couple revisions. I mainly went to the dyno for experience as it was my first time, and also to squeeze a couple extra ponies out for fun, which ended up working out pretty well! |
| The Following User Says Thank You to Dzmitry For This Useful Post: | ZDan (04-25-2021) |
#32 |
One thing to add to my dyno as well, is that the tuner explained to me that he could smooth out and get a tiny bit more right at the peak, but it comes with some small risks. I don't exactly recall what it was, but the tuner did mention that no one he had ever known had experienced any issues with doing the extra little bit up top, so he gave me the option of whether I wanted that little bit or not. Since I am not tracking or crazy about an extra couple HP up top, as it is mostly my DD, I just had him leave it at that. And again, I can't speak much for comparison to stock or anything, but I can tell you the car feels fantastic all around and is plenty quicker than she was stock. I do have a video of me going through 2nd gear from 2.5-7.5k RPM. My plan with that was to compare it to now, I just haven't gotten around to making a video since my header and tune. But when I do, I can post my results.
#33 | |
Drives: '23 BRZ
[img]https://cimg0.ibsrv.net/gimg/www.s2ki.com-vbulletin/1170x725/2017brzdyno_32aaf4b1cd5054ee15ad9d77006c0d0f8d***f 56.png[/img] Like you suggested, the ACE seems to fill in and add to the midrange, but nothing up top. Same 178rwhp peak, but mine maxes at 138 lb-ft way up at 6500-6800, ACE seems to max at higher torque, 145 lb-ft, but down around 4500rpm. So yeah, bumped-up/filled-in midrange but nothing more up top. Thread you linked to, dark plots are ACE, right? Similar dropoff at 6500: ![]() Hmmm... |
#34 | ||
Drives: '23 BRZ
#35 |
Drives: '23 BRZ
Might make another thread for this, but since there's no way *I'm* gonna install this header between now and track days May 8/9, does anyone know a good Subie shop in Boston/Providence/eastern CT region to install a header? TIA!
#36 | |
It also seems to vary from car to car significantly. Many of our cars don't truly peak at 7k RPM. Here's an popular example you may have seen in the past that shows ACE making strong gains over stock, peaking very well over stock, but not at 7k. https://www.ft86club.com/forums/show....php?p=3047845 In the end, I believe your concern is that you will not get any gains up top and actually lose power earlier / shift the peak? I don't believe that is the case I am making here. Simply, that there are peak focused headers out there that can make more right up top than this one. But this header tends to add some of the highest gains OVERALL throughout the curve and is fantastic for track. There could also be some discrepancy, as my car is 2017+, while yours is pre if I'm not mistaking? |
| The Following User Says Thank You to Dzmitry For This Useful Post: | ZDan (04-28-2021) |
#37 | |
Drives: 2014 BRZ Limited
He is a perfectionist, and from my personal experience he is very professional and fast to send out revisions. He'll answer all your questions politely and in detail, there are no "stupid questions" with him. Highly recommended to go with CSG for tuning. |
#38 | |||
Drives: '23 BRZ
#39 | |
Look forward to hearing your thoughts and results on it! |
#40 |
Drives: '15 BRZ RA
Do you have an oil cooler? If you go with a leaner tune and a catless header , then engine temperatures will go higher. As usual, you change one thing and then you need to change other things. Not sure how well this will work with your classification points.
| Agency Power EL Header, Vibrant o2 spacer | ptschmidt77 | Engine, Exhaust, Bolt-Ons | 3 | 02-13-2020 09:37 AM |
| Small spacer vs big spacer | Atomic Rooster | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 11-09-2017 02:30 PM |
| FS: Borla UEL Header with O2 spacer | yutinggao | Canada Classifieds | 0 | 09-05-2016 03:42 PM |
| Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-03-2014 01:53 PM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 12:59 PM |
