#15 | |
Drives: Toyota 86
#16 |
Drives: 2017 86 860 Special Edition
Roll stiffness for the front is required in a macpherson strut because its camber curve causes it to stagnant or even gain camber during compression. That's why there is a large amount of static negative camber required to offset this. The rear is a different matter, and over all the suspension should be looked at with a holistic approach. It's really not going to matter until you start looking at fine tuning your suspension to iron out certain issues ie. mid corner grip, bump steer etc.
| The Following User Says Thank You to RayRay88 For This Useful Post: | ninjan00dles (04-28-2021) |
#17 | |
That's true for the rear, but the fronts gain no camber (and actually lose some at peak compression) through compression.
#18 |
Drives: 2014 GT86
Compared to rears fronts gain a bit dynamic camber when turned from caster though, even if they don't gain from compression. Then again, no that much at small turn angles, which is more common in smoother track driving.
#19 |
Drives: '23 BRZ
Yeah, people always seem to miss that point. Even for medium speed corners the camber gain from caster is minimal. Personally I prefer to keep caster minimized and if that means I need to add another 0.1 degrees static camber, fine...
| The Following User Says Thank You to ZDan For This Useful Post: | wparsons (05-12-2021) |
| SPC control arms and toe arms, whiteline camber bolts | Tacticalpanda | Brakes, Suspension, Chassis | 4 | 10-23-2020 12:04 PM |
| lowering without aftermarket rear control arms | littlealex | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-26-2019 03:53 PM |
| Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 03:08 PM |
| Spc control arms and negative rear camber question | pbirmingham1988 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 08-20-2016 02:57 PM |
| SPC Lower control camber arms so cheap? | SliverBrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-17-2013 09:33 PM |
