Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 03-18-2021, 11:29 AM   #57
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by gen3v8 View Post
I said 15-20% My glass is half full @ 15% your glass is unfortunately half empty @15%. 15% of 205 would only make it 230
Originally Posted by Dzmitry View Post
If we're going to do number calculations, it would actually be ~236 - and that doesn't change what I said, as a whopping 30HP gain is extremely unlikely on just a header and tune. You might be looking at around 10 for a typical off the shelf tune and maybe up to 15 from a solid revised E-tune. 15HP is a little over 7%.
I'm not here to pick a fight with ya, just saying that you shouldn't expect or give others expectations of those kind of gains. I bought what is known as one of the best headers on the market for this platform along with a cat-back. I also got Ecutek and a few revisions from one of the best tuners for this platform on the east coast. I even went to his dyno later on for the hell of it to get the experience and wring out a few extra ponies. End result was 178whp. Though I never got a baseline, I certainly don't believe I ever gained anything close to 30HP. It feels stronger up top, but not by much.. Keep in mind, too, that I went above and beyond what the majority of people here would do.
@9 minutes. They dyno'd stock and with headers+tune. Ignore the click-bait title, but they did make good gains.
Maybe we have a middle ground?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 03-18-2021, 11:43 AM   #58
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
15-20whp gain is seems doable with a good tune and a catless header. For peak numbers to matter you need a baseline to compare it too. Some cars baseline as low as 145-150whp on certain dynos, others as high as 170whp.
All that matters is the spread to me. A high reading dyno looks good on paper when you show it to someone.
Old 03-18-2021, 11:44 AM   #59
RToyo86
RToyo86's Avatar
That's also with the header already installed but untuned.
The difference probably would have been even larger if it was bone stock.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
BrahmaBull1990 (03-18-2021), Dzmitry (03-18-2021)
Old 03-18-2021, 11:49 AM   #60
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Again, I'm not saying it's not obtainable, there are certainly manufacturers that have claimed such gains, and proved it with their dyno's. They just don't reflect the majority unfortunately. Also, this is again beyond what most folks actually do, which is taking it to a dyno as it costs a pretty penny. An off the shelf tune is probably the biggest seller for this platform. A couple things to note with this as well - This is a 2013 model, 200 vs 205 HP, more gains to be had than the facelift. And then as stated above, the base was with the header on, which has proved multiple times to give some minor gains without a tune.
EDIT: Got myself mixed up, the header already on could side with getting even more gains over stock.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
Old 03-18-2021, 11:49 AM   #61
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I mis-spoke. Another video had their stock dyno-run, but at the end they have a chart up of a stock dyno-run for comparison (just not this exact car).
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
Dzmitry (03-18-2021), RToyo86 (03-18-2021)
Old 03-18-2021, 11:54 AM   #62
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Again, I'm not saying it's not obtainable, there are certainly manufacturers that have claimed such gains, and proved it with their dyno's. They just don't reflect the majority unfortunately. Also, this is again beyond what most folks actually do, which is taking it to a dyno as it costs a pretty penny. An off the shelf tune is probably the biggest seller for this platform. A couple things to note with this as well - This is a 2013 model, 200 vs 205 HP, more gains to be had than the facelift. It's older and used, stock header cat could be a bit beat up and would result in lower stock numbers. And then as stated above, the base was with the header on, which has proved multiple times to give some minor gains without a tune.
I thought that 5 ponnies was from the updated stock intake maifold, etc, which was never upgraded on this car? So the percentage increase would be the same, just a lower trough to peak, if you will, on the 2013. Would the degradation in performance be that noticeable on the baseline numbers, assuming the car does not have 150k miles on? (genuinely do not know)
Old 03-18-2021, 12:02 PM   #63
Dzmitry
Dzmitry's Avatar
Not quite. Though what you say is true, the HP was gained from the additional tune-up, if you do a little research on how this affected peoples gains, you will find that it diminishes. In simpler words, lets say the peak power people achieve with the 2013 is about 200 whp. The same thing applies for the 2017+ models, it is still about 200 whp. So you don't get an extra 5 up top for owning the later models, the gains are lessened.
Why is that? Simple, because of exactly how this conversation began, the engine is already near its peak. There is only so much you can do to it.
Old 03-18-2021, 12:05 PM   #64
Dzmitry
Dzmitry's Avatar
And to answer your other question, it can be, it just depends. A clogged cat or a very dirty air filter, or crap built up in the engine, and plenty more can all have affects on your output. I have seen some dyno's where gains seem way too good to be true. But when you look into them, you notice things like the peak power dropping off earlier than normal, etc. This likely means the base car already had some kind of an issue before the mod, and the mod may have resolved it as well as provided gains.
Old 03-18-2021, 12:07 PM   #65
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
This makes sense! The ceiling is the ceiling...the 2017+ models just have a head start. Gotcha! Thank you
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Old 03-18-2021, 12:16 PM   #66
RToyo86
RToyo86's Avatar
They made a bunch of small changes but most seem to be reliability/livability improvements.
The factory tune and the updated factory header are the big changes on 17+ cars. It has larger runners compared to the older design, similar to aftermarket headers. But it still retains the same huge restrictive cat. There is a thread buried somewhere indicating the differences.
Once aftermarket parts are thrown on I don't think anyone has been able to provide a measurable difference between the revised engine and the old one.
There is a build thread with custom tuning done on a stock decatted 17+ header and front pipe which showed comparable gains to most aftermarket catless setups.
Old 03-18-2021, 12:20 PM   #67
Dzmitry
Dzmitry's Avatar
https://www.ft86club.com/forums/showthread.php?t=133311
The dyno is on the first page a bit down.
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
BrahmaBull1990 (03-18-2021), RToyo86 (03-18-2021)
Old 03-18-2021, 06:07 PM   #68
gen3v8
Barred
gen3v8's Avatar
Drives: My18 wrxsti My19 brzts
All good mt friend, Just to remind you crank hp gains versus whp are different whp being lower but the % is the same.
Pulse Racing have a Happy Dyno. They boast big numbers and do good work and their dyno like all dynos is a tuning tool. I had one of my cars(turbo) done by them it came back @ 212Wkw. I went to a dyno day and it made 187wkw which was good on the day compared to others of similar mods. Baseline on the day was 130+-140+ wkw stock.
Wait until my Flex capacitor hits 88
gen3v8 is offline   Reply With Quote
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
BrahmaBull1990 (03-18-2021), Dzmitry (03-19-2021)
Old 04-07-2021, 05:08 AM   #69
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Originally Posted by BitusB View Post
Is it necessary to swap out stock header to address torque dip or can a tune alone do the trick? I prefer to have a cat for sound and environmental reasons.
I also had the same environmental concern & opted for catted aftermarket one. This is the setup I did for my old FRS that completely removed the dip while having earlier pull at around 3.3k rpm via Crawford BPB
FT86 Speed Factory UEL, catted
Crawford Billet Power Block (BPB)/Intake Manifold Spacer
OFT w/ Crawford BPB Tune
To further reduce my environmental impact, I take the electric to work & only used the car on weekends or short trips to Costco.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
torque, torque solution, tune
Search this Thread:
Advanced Search
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 05:02 PM
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 05:09 AM
Torque Pro sav AFRICA 33 08-27-2013 08:31 AM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 07:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
