#1275 |
Drives: Toyota 86
Un! Natapos ko din basahin 64 pages.
I have my L. Red 86 last 2 weeks p. sana mksama ko nxt n eb. Thanks nga pla mga useful infos n ntutunan ko dto. ASTIG TLGA 86!!! |
#1277 |
Drives: Toyota 86
#1278 |
#1279 |
Drives: none planning to buy
sorry mga sir pa-OT; what did you do sa gt86 DRL to light? gusto ko sana paganahin yong DRL sa 86 ko. thank you guys.
#1280 | |
#1281 |
Sending rods to their doo
Drives: 700HP STi
mga pre, sino sainyo ang gusto mag trade para sa USDM Badges ko?
#1282 | |
Drives: RED BRZ
To enable the DRL on the 86, just add a relay in the DRL slot of the fusebox located in the engine. The DRL will light up when the car is running and the handbrake is disengaged. For the BRZ, aside from adding the relay, you will have to buy and install the BRZ LED DRL assembly which will have to be installed above the foglights on the bumper. Last edited by NIKDENG; 08-10-2013 at 01:12 PM. |
#1283 |
sir NIKDENG, do you have tha part number of that fuse your telling me? just want to be sure the fuse im going to buy is the right fuse.
#1284 | |
Drives: RED BRZ
It's not a fuse, its a relay on the engine fusebox. The relay type for the DRL is the same as that of the horn relay. If you want to test the DRL function, temporarily use the horn relay and place it in the DRL location. The diagram and the relay locations are as follows: ![]() The red box is the DRL relay location, the green box is Horn relay location. When you are going to buy a relay for the DRL, just bring the horn relay as your sample. Remember when testing your DRL, the engine must be turned on and the handbrake disengaged. Last edited by NIKDENG; 08-10-2013 at 02:00 PM. |
| The Following User Says Thank You to NIKDENG For This Useful Post: | melon (08-13-2013) |
#1285 |
thank you sir NIKDENG.
OT; typical FC for 86/BRZ? |
#1286 |
nice to know that you just need a relay for you to have the DRL in the 86 work though i wish they just made it work just like the usual DRL wherein as long as the ignition is on, the DRL lights up as well
#1287 | |
Drives: RED BRZ
The 86/brz actually follows the standard DRL implementation of the DRL lighting up whenever the engine is running and the handbrake is deactivated. They should turn off when the headlights, parklights, or foglights are turned on or when the handbrake is activated. |
