Old 02-26-2021, 06:01 PM   #15
Purist
Purist's Avatar
Drives: Subaru BRZ
Originally Posted by series420 View Post
another thing i should mention is, i intend on using this vehicle for SCCA autocross.. I will have to get high flow cats sadly
Do they check emissions or what?
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-27-2021, 01:28 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
They might simply require for car to be street legal. And that includes passing emission tests. I don't get "sadly" bit though. I certainly don't want for all cities to be full of smog and be glad about it.
Old 02-27-2021, 04:13 AM   #17
Purist
Purist's Avatar
Drives: Subaru BRZ
Originally Posted by churchx View Post
... I don't get "sadly" bit though. I certainly don't want for all cities to be full of smog and be glad about it.
True, but E85 is up to 85% ethanol, which doesn't produce oxides of nitrogen when it burns. So it might still pass with no cat.
Anyone...?
Less More
Old 02-27-2021, 06:13 PM   #18
gen3v8
Barred
gen3v8's Avatar
Drives: My18 wrxsti My19 brzts
Anyone...?
The gas content of it will still make NOx,Wont it?
Wait until my Flex capacitor hits 88
gen3v8 is offline   Reply With Quote
Old 02-27-2021, 08:08 PM   #19
ermax
ermax's Avatar
e85 questions
Originally Posted by elBarto View Post
You can change the "Cranking Fuel Injector Pulse Width" tables in RomRaider/ECUTek, In an old Wayno topic are the values.
Mine started in -10°c (14°f) on first crank.
An extra con of E85 (ethanol in general), it's hygroscopic, meaning it attracts water. But that can be fixed with daily driving it.
Yep I spent a few years dealing with starting problems but finally got a chance to play with the cranking tables and now it starts first try all the time. I’m in Florida and the lowest I’ve cranked it since the change so far was 38F. Before the adjustments it took two starts once the temps dropped bellow 60F.
Old 02-27-2021, 08:13 PM   #20
Purist
Purist's Avatar
Drives: Subaru BRZ
Yes, of course. But only 15 % of what 98 would. I was wondering if that might be sufficient to pass emissions.
Do cats remove 100% the NOx?
Less More
Old 02-27-2021, 08:14 PM   #21
ermax
ermax's Avatar
Speaking of bad gas mileage. I just calculated my MPG on a full tank and got 18.9mpg on E85. I mostly drive my car like I stole it so I’m sure I could do better but I’m curious what others are getting.
Old 02-27-2021, 08:17 PM   #22
Purist
Purist's Avatar
Drives: Subaru BRZ
Is this the relevant clause?
Street Touring X Class: The "precat(s)" and primary catalytic converter may all be replaced by a single converter, provided the resultant configuration meets Federal emissions inspection standards at normal vehicle operating temperature."
Disclaimer: I don't even live in the states. Just curious.
Less More
Old 02-28-2021, 11:40 AM   #23
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
That's about what I get and I drive abut the same as you. Dead stock except for a Borla axleback. I would advise anyone
considering a switch to make sure there's a reliable source of it nearby. There is only one station that carries it in my town. If I go on the road I carry 4 gallonsw in the truck. A great many stations that show it online don't really have it. Of course I carry the OFT in case I have to switch back.
Qwimby1 is offline   Reply With Quote
Old 03-03-2021, 03:56 AM   #24
series420
Drives: '13 Toyobaru BRZ
aye the rules for street touring specify
"Catalytic converters: Any catalytic converters are allowed, but must attach within 6” (152.4 mm) of the original unit. Multiple catalytic converters may be replaced by a single unit. The inlet of the single replacement converter may be located no further downstream than 6” (152.4
mm) along the piping flow path from the original exit of the final OE
converter. The extents of an OE converter are defined by the expansion
chamber in which the catalyst is contained, regardless of placement
within larger exhaust sections. Replacement converters must have a
minimum catalyst density of 100 cells per inch and minimum substrate
length of 3” (76.2 mm)."
2013 BRZ Premium
Injen short ram intake, OFT Stage2/e85
Ftspeed UEL headers, JDL front/overpipe, HKS high power dual outlet catback
series420 is offline   Reply With Quote
Old 03-03-2021, 04:45 AM   #25
Purist
Purist's Avatar
Drives: Subaru BRZ
[QUOTE=series420;3410833]aye the rules for street touring specify
Sounds like the catted headers you were planning are allowable,
(I'd confirm that in the tracking forum) a stated increase of 14 bhp at peak, add E85 for another 20. You won't know yourself!
Don't waste your money on a cat back or axleback, they add 2-3 bhp at most.
Something no one tells you about E85... It has a strange smell...
Less More
The Following User Says Thank You to Purist For This Useful Post:
series420 (03-03-2021)
Old 03-03-2021, 11:53 AM   #26
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Jumping on this thread for some additional info. I just found out there's a navy base near me that has E85, apparently 85%. Currently running JDL UEL Catted headers with full rest of exhaust, stage 2 OFT. I should probably get a Flex Fuel kit. I was reading on a past thread that there's a way to use 85 without the kit, involves something among the lines of running for about 2-3km at low RPM until the LIFT values increase to a certain degree, then stop the vehicle, load E85 Tune, and let the ECU learn the new tune slowly. Figured, while I still can, use my military ID and get gas whenever I need it. Any more additional info would be great.
Old 03-03-2021, 12:48 PM   #27
gen3v8
Barred
gen3v8's Avatar
That`s it Just make sure you are as near to empty as possible first. Last time i switched to e85 the engine was stumbling before i put the tune in. The e85% increases with the next fill as the gas gets cleared out. If you go a distance and may run out of e85 keep your oft with you for an emergency switch back tune to gas.
The Following User Says Thank You to gen3v8 For This Useful Post:
spcmafia (03-03-2021)
Old 03-03-2021, 05:07 PM   #28
Purist
Purist's Avatar
Drives: Subaru BRZ
https://r.tapatalk.com/shareLink/top...ink_source=app
How to run E85 on stock 86 BRZ FRS with OFT tune
I have been doing this for over 3 years. Zero issues. Never going back unless I can't get it. Then I just flash back to 98. 5 minute job.
If you want peace of mind, keep an eye on your ignition advance multiplier. If it drops below 1 it means it's detecting knock. (It won't)
Less More
e85
Search this Thread:
Advanced Search
TRD Kit Questions Dboe Cosmetic Modification (Interior/Exterior/Lighting) 9 09-26-2016 10:26 PM
few questions jxl00 Engine, Exhaust, Transmission 3 09-24-2016 03:59 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 12:19 PM
Sub + Amp Questions itdansharpe Electronics | Audio | NAV | Infotainment 29 07-08-2013 01:42 PM
Questions about CEL DarkSunrise Issues | Warranty | Recalls / TSB 7 08-31-2012 01:42 PM
