#1219 |
Drives: None
Nope, you’re good as long as your new sensor is reading as you expect.
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | funkjaw (08-11-2022), Irace86.2.0 (08-10-2022) |
#1220 |
Drives: Q5 + BRZ + M796
I don't know if anyone saw this. I'm guessing that is a G25-660. It looks like it and seems to be what they have used in the past, but I don't know what trim they are using. They haven't released specifics, but it seems to be internally gated, and they are working on a transmission. I'm sure they will go with a BMW unit like they have in the past, but I wouldn't mind a CD009, as that is what I would prefer. I could always do a Collins kit or something else, if I don't care for the transmission choice they use. It also looks like they relocated the washer filler up higher, and there seems to be an aluminum canister in place of the old unit:
| The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
#1221 |
Drives: None
I wonder what changes would be needed to make the mounts work with a K24Z. Seems better on paper for turbo packaging / heat management.
Also curious about the transmission option, I'd be happy to offload my Jack's Transmission and hopefully break even.
#1222 | |
![]() I would need to offload my driveshaft, transmission mount, shifter, flywheel and transmission adapter to upgrade, so I’m expecting a decent loss, unless wait times are still long. I bet you could break even.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | RedReplicant (08-13-2022) |
#1223 |
Drives: 13 White MT FR-S
did Redreplicant's wiring harness fix yesterday and can confirm it was very simple fix. All the parts came really fast and cost less than 20$
| The Following 3 Users Say Thank You to ML For This Useful Post: |
#1224 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
| The Following User Says Thank You to captain awesome For This Useful Post: | RedReplicant (08-13-2022) |
#1225 |
Going to VIR Thursday so we will see if it’s a sensor or oil starvation issue
#1226 |
Drives: 16' WWB
Ran against a friend's 2020 Ecoboost Mustang A/T Convertible. His car is bone stock, my KRZ was on ~E30 fuel
https://youtube.com/shorts/QubxM2vCCVk Obviously not the most crazy of kills, but considering that a stock EcoBoost Mustang is normally a full 1 second faster in 0-60 over a stock twin, I'd say these results show just how much quicker doing this swap makes these cars. |
| The Following 2 Users Say Thank You to funkjaw For This Useful Post: | Irace86.2.0 (08-15-2022), ML (08-14-2022) |
#1227 |
Drives: None
Had my stock DS shortened 5.5" per captain_awesome's specs, I'll test it this week. Cost $395, hopefully it makes a noticeable difference
| The Following 5 Users Say Thank You to RedReplicant For This Useful Post: | captain awesome (08-16-2022), FrickingReallySlow (08-15-2022), funkjaw (08-16-2022), Irace86.2.0 (08-16-2022), ML (08-15-2022) |
#1228 |
Drives: 16' WWB
Absolutely give us an update! NVH in this car is starting to put a hamper in my fun... cuz it's hard to have fun if I am worried about everything rattling apart.
| The Following User Says Thank You to funkjaw For This Useful Post: | RedReplicant (08-16-2022) |
#1229 |
Wears Pants
I really hope it helps as well. I'd feel like a piece of crap if you saw little change as it's not a cheap fix. I've put about 5k miles on my shortened driveshaft but from my notes it was night and day difference. Coupled with removing the poly trans bushing it's so much more daily driver friendly. I may still pop the STI trans mount back in though. Pretty sure I'm overworking the floppy stock one.
| The Following User Says Thank You to captain awesome For This Useful Post: | RedReplicant (08-16-2022) |
#1230 | |
Drives: None
I ordered spacers/bolts from mcmaster so I should be able to test on Wednesday/Thursday. I'm weighing chopping out the ~3" flex section of the Perrin and replacing it with a longer 6" flex section in effort to keep the header alive, not sure if it is worth it though.
#1231 | |
Wears Pants
I keep checking mine to see if I have any signs of cracks but nothing yet. From the pics of failed welds I've seen so far it looks like poor filler/penetration that's the culprit. Maybe I got lucky on my set? I'm also still looking into my shortened stock shifter assembly when the new built block is finished. Just need to drop it by my welder to have it glued together with the TIG. This would help the buzz coming from my stock shift knob around 3-3500 rpm. |
| The Following 2 Users Say Thank You to captain awesome For This Useful Post: | funkjaw (08-16-2022), RedReplicant (08-17-2022) |
#1232 | |
Drives: 16' WWB
They claim it eliminates the rattle that comes from the loose tolerances on the stock lock-out unit. I'll update once I install it. |
| The Following User Says Thank You to funkjaw For This Useful Post: | RedReplicant (08-17-2022) |
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 04:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 02:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 02:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 05:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 02:00 AM |
