#15 | |
Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Plumbus (12-26-2020) |
#16 | |
Drives: jrsc_brz
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
#17 | |
#18 | |
Drives: 2017 toyota 86
Ace is 9.75lbs + OP 3.5lbs = 13.25. So ace is almost 12.15lbs lighter. Stock CBE is 38lbs so if his is actually 48lbs that’s not doing anyone any favors. I believe csg mxp touring 86 is 35lbs. So OP could drop 25+ lbs and gain about 25whp and make his exhaust quieter by making the swap. |
#19 |
Drives: '20 Hakone 86
Could drop 20lbs off the front just by switching to the AP Racing brake kit. And that's unsprung (and some rotational) mass as well.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | PulsarBeeerz (12-22-2020) |
#20 |
Or Wilwood for 30lbs
#21 | |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
I have the FT86 catted UEL & 2019 TRD SE exhaust. Though it's factory, I felt that the noise can still be a cop magnet. What I've done which is quite effective is I have wrapped the front pipe & mid pipe with Design Engineering Form-A-Shield which is basically a thick yet very light thermal insulation. This absorbed the tonal frequency of the pipes & created muffled the exhaust's mid-high "tin can" note & left what sounded like a bassy hum. My family can definitely notice how much quieter it is in the cabin. If you wrap the muffler/resonator, the sound will definitely be more muffled as this it's the last area where air & the metal reverberate. Since you're also into weight reduction, have you also tried switching to aluminum/cf drive shaft? It's approx 12 lbs lighter than stock & lets you accelerate faster. Light racing wheels that are less than 18 lbs like Enkei RPF1, Enkei PF01, & Motegi MR140 to name a few fall in that category even at 18x8.5 vs 20 lbs of 17x7 stock will not only help reduce weight but also improve the handling.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
#22 |
Weight reduction
Rear Total -57.5lbs Remove Spare/tools -30lbs DIY Rear seat delete kit - 25lbs and reduced in cabin noise Catback Exhaust -2.5lbs Middle Total -35lbs Driver/Passenger Bucket Seats -24lbs Carbon Fiber Driveshaft -12lbs Decat FP -1lbs Front Total -99.5lbs Wilwood BBK -32lbs Shorai Battery -24lbs JDM AC Delete -14.5lbs never used the AC until AFTER removing it just for the fans, worked well. Ace Header/OP -12lbs Mini windshield reservoir -8lbs Beatrush Crash bar -5lbs Verus Injector covers -4lbs Total Weight reduction -192lbs Wheels dropped 3lbs a corner but tires added 3lbs so it was a wash but more grip. |
#23 |
lightweight carbon driveshaft will have no improvement to acceleration (well technically .1%) aluminum one being much larger diameter will actually decrease acceleration and most people notice a noise at higher mph.
#24 |
Nice weight reduction list. If you get the 12.7lbs exedy lightweight flywheel, you’d be at a nice -200 lbs.
2022 BRZ Build 2013 FR-S Build |
#25 |
#26 |
Drives: 2013 FR-S Series 10
At 6'0 230 i know the easiest and yet hardest weight loss mod.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| The Following User Says Thank You to Decep For This Useful Post: | alphasaur (12-27-2020) |
#27 |
Drives: 2016 Toyota 86
#28 |
Wilwood 4R are 32lbs lighter then stock. Not as good of brakes as AP, but also a lot cheaper and the lightest. Solid upgrade still like. Doesn’t change brake bias. For a DD it’s very good or an NA track build that’s had some solid weight reduction.
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Mike_ZN6 (12-26-2020) |
| VVT Tuning Noise - ADDED: Comparison Video | Dezoris | Software Tuning | 349 | 01-27-2020 04:46 AM |
| Swoosh noise headers | NoobBRZ | Engine, Exhaust, Transmission | 18 | 01-31-2018 03:12 PM |
| Exhaust Cabin Noise, MXP UEL Headers and OP, Tsudo Catback | HachiEnam | Engine, Exhaust, Transmission | 25 | 12-15-2015 06:47 AM |
| Road and Track: Tune + headers + axleback added to long term BRZ | tennisfreak | Engine, Exhaust, Transmission | 42 | 01-07-2014 04:31 PM |
| [Bought] Borla (or lighter) headers | Anthony | Want-To-Buy Requests | 4 | 08-28-2013 12:55 PM |
