86WORX
Old 12-14-2020, 02:17 AM   #15
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by gen3v8 View Post
He supplied hi-res pictures so are people blind, stupid or ill informed. The simple fact is the front bar has cracks from impact damage visible in the pictures which have limited view. OS has a stress fracture in paint running the opposite direction to the split near the end of the split. The OS also has a cracked black plastic fascia below the headlight ( looks pushed in and a 1/4" gap with a 1" crack).
The NS has an extra tear that started but ceased because it tore at the split 1st. It also has cracks or damage to the black headlight surround near the split that has contacted the bar and caused minor damage to the bar also. If you compare both pictures in these corners where the split starts you will see the different clearances of the bar and the headlight surround where the bar has settled after an impact.
If course it has been hit.
gen3v8 (12-14-2020), spike021 (12-14-2020)
Old 12-14-2020, 09:09 PM   #16
spike021
spike021's Avatar
Just to add my two cents:
Last year someone in a Silverado backed into my parked car (nose pointing out) at work. I had to get the bumper repaired and repainted.
This is an example of what it looked like post accident:
Basically after the repair, I noticed a similar (though much smaller) hairline crack and slight webbing (can't even be seen in the photo) right in the same spot on IIRC the driver side where the bumper meets the corner of the headlight.
So anyway, I bet your car was in a similar accident, although it seems like it took more force than mine did.
It seems like if the body shop doesn't do a great job with the clips they can also cause those types of cracks.
Sorry man .
Instagram: @spike.brz
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
Ultramaroon (12-15-2020)
brz, bumper, cracking
Help please, cracked bumper lizbrayan Cosmetic Modification (Interior/Exterior/Lighting) 16 04-04-2019 03:55 PM
Dealer cracked the paint on the bumper during PDI ayau Issues | Warranty | Recalls / TSB 34 07-26-2018 06:39 PM
Saggy bumper after accident Vincenttam Southern California 28 05-16-2016 05:18 PM
Front bumper scratch by accident impossible Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 55 08-25-2014 10:04 PM
