#15 | |
Exhaust Lord
Drives: 2016 Scion FR-S
Okay if you need you can send the videos to my insta YSoAggressive, very interested in this if it doesn’t really have much drone because I’ve been looking at different single exits that can replace my current Invidia N2 + Tomei UEL setup otherwise if there is none I’ll just get the CSG Touring 86 |
#16 | |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
| The Following User Says Thank You to Westen86 For This Useful Post: | YSoAggressive (06-30-2021) |
#17 |
So what I have done is modified my stock FP and added a much larger resonator. Also look at this thread. These hangers really help with drone.
Resonator I used and had a shop weld into my FP: Vibrant 1140 2.25" Ultra Quiet Resonator Thread for JP Spec STI hangers: https://www.ft86club.com/forums/showthread.php?t=143514 I would try these 2 things before you swap FPs and exhaust
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | YSoAggressive (06-30-2021) |
#18 |
Exhaust Lord
I know the CSG Touring 86 is the answer to pretty much no drone setup but I was wondering if the HKS HI Power Single V2 had low drone as well or at least less than what an Invidia N2 + UEL headers would give you because I do like the single exit look. I’d much rather have it but if this isn’t an ideal option and the drone is pretty much the same if not even worse than what I already have for my setup I’ll definitely just go with the CSG Touring 86. That’s what I’m trying to get at and trying to figure out here.
#19 | |
Exhaust Lord
#20 | |
#21 |
Exhaust Lord
#22 |
compared to the N1/2 the HKS might have a bit less but most single exits are very loud and drone. Drone does not = loud. As i listed in your other thread, Lots of options with dual exit exhausts if your looking to cut out drone. Honestly what I would do is get the resonator I suggested and get it welded in. See if it cuts down on the drone. From there I would pick your catback.
#23 |
Drives: 2015 FR-S
I also have the HKS HI-Power...I ordered a silencer for 55$. Its suppose to take the noise level down to the same level as V2. I'd try that route first
| The Following User Says Thank You to FrickingReallySlow For This Useful Post: | YSoAggressive (06-30-2021) |
#24 | |
Exhaust Lord
#25 | |
Drives: Crapcan
https://shop.namelessperformance.com...et-track-pipe/
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | whataboutbob (06-30-2021), YSoAggressive (06-30-2021) |
#26 | ||
Drives: 2014 Ultramarine FR-S
I used to own the Blitz too, but had stock header, so can't give you an impression with a catless header. But here's an impression from another member: Quote:
#27 | |
Exhaust Lord
#28 |
| WTB: Tanabe Medallion Concept-G single exit Cat-back Exhaust | akthegreat | Want-To-Buy Requests | 1 | 05-20-2020 03:01 PM |
| ISO: Single exit cat back exhaust or hks power exhaust | nk4e | Want-To-Buy Requests | 1 | 07-14-2019 05:01 PM |
| Single Exit exhaust (Passenger Side Exit) | SlammedSilly | Engine, Exhaust, Transmission | 25 | 06-09-2016 01:17 PM |
| FT-86 SpeedFactory - V2 Single Exit Cat Back Exhaust - RELEASED | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 51 | 08-26-2015 12:23 PM |
| Cat Back Single Exit | Depo Racing | Engine, Exhaust, Bolt-Ons | 6 | 05-08-2015 05:13 PM |
