Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 03-31-2021, 10:49 AM   #1555
Transport3r
Drives: -
Another point to consider is that just because the static CR is now higher doesn’t necessarily mean that the minimum dynamic CR that can be achieved by valve timing is any higher than before. If they’re going to sell the cars in NA, they have to be able to at least run reasonably well on 87, I’m sure that requirement is the same as before. Between valve timing, ignition timing, and advances in DI tech over the past 10 years, I don’t think it’s unlikely at all.
Transport3r is offline   Reply With Quote
The Following 2 Users Say Thank You to Transport3r For This Useful Post:
Cephas (03-31-2021), ZDan (03-31-2021)
Old 03-31-2021, 11:24 AM   #1556
Originally Posted by ZDan View Post
They likely have the same basic requirements regarding how well it runs on 87 for the new model as for the current one. Could be improvements to combustion chamber design, fueling, and spark control make it possible to have the same "driveability" with lower octane fuel with the increased compression ratio.
long/short: I wouldn't worry about it... Especially since we're all gonna use 91 octane minimum anyway!
They were concerned enough with the old ones to say NOT to use 87 so even if it "stays the same" they are not suddenly going to say it is OK.
Transport3r (03-31-2021)
Old 03-31-2021, 11:38 AM   #1557
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, of course they'll say not to use 87 and will specify 91 minimum. I'm just saying they likely haven't changed their requirements for how the engine deals with lower-octane fuel should it find it's way into the engine. I would guess that the new engine's susceptibility to damage or poor-running from lower-octane fuel is the same as the current lower-CR engine. I.e., nothing to worry about for most of us.
Old 03-31-2021, 11:40 AM   #1558
Sasquachulator
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
IF the gas cap says recommended 91+ or whatever you might be able to get away with using 87.
If it says required 91+ dont even dare put less than 91.
Old 03-31-2021, 12:16 PM   #1559
Transport3r
Drives: -
All-New 2022 Subaru BRZ Makes Global Debut
Agreed, but as @ZDan pointed out, someone will. Subaru likely has a requirement that there engine can run on 87 (once ) without sustaining long term damage. We’ll probably never know for sure though.
Old 03-31-2021, 12:49 PM   #1560
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Run 87 and you risk your car going POOF!!! No guarantee for it to blow right away of course, but you can pretty much guarantee to experience detonation. The only question is how long will the engine handle it.
EDIT: To add to this, with knock sensors and modern tech, the car does adjust accordingly, so I'm sure it does a decent job of lowering your power to prevent damage. It would certainly be a bad idea to push the car in any way when running on lower octane fuel.
Dzmitry is offline   Reply With Quote
Old 03-31-2021, 01:38 PM   #1561
Somehow this went from "the car will do it but run like crap" to "it will blow up if you put one drop of 87 in".
If it has to pull timing and change fuel mix at the lower compression it will have to do even more at the higher. Pull more timing run even crappier.
Old 03-31-2021, 01:51 PM   #1562
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
You can push all you want. The ECU will say, “Thanks, but no. Here is your 180hp (or lower) peak.”
Quentin is offline   Reply With Quote
Old 03-31-2021, 02:14 PM   #1563
Dzmitry
Dzmitry's Avatar
Right, but the ECU will say this after there is some detonation - which could result in potential damage, but shouldn't I guess. I'm not very experienced on understanding the details in how quickly the ECU adjusts and whether it keeps the power low afterwards. My assumption would be that it always allows some detonation - quickly learns, and adjusts air/fuel and timing... then after some period of time it repeats this cycle, therefore always allowing some detonation to occur that could lead to some damage. Could be totally wrong.
Old 03-31-2021, 02:37 PM   #1564
Transport3r
Drives: -
Modern ECUs are extremely fast at catching detonation and saving the engine. BMW’s N54, their first DI Turbo I6, had a few aftermarket boost contollers introduced that would increase boost pressure only and let the ECU figure out the test. They needed some ‘adaptation runs’ IE let the ECU figure out where it knocks badly so it can adjust timing. Nowadays proper tuning solutions exist for that platform, but still, nobody blew a motor from letting the ECU handle knock control, even waaaaay outside factory parameters.
The Following User Says Thank You to Transport3r For This Useful Post:
Dzmitry (03-31-2021)
Old 04-01-2021, 01:01 PM   #1565
TheDonEffect
Drives: A mix
It happens, frequently. You're on a road trip, pull up to some old gas station, out of gas, only 87 in stock. Loan your car out an unsuspecting person, they put in 87. And of course, just variations of gas and gas quality.
I mean, would I put in 87 and then go thrashing it at a track? No, but could I put 87 and finish the last leg of a road trip? I wouldn't think twice about it.
Do I expect it to run at optimal levels? No, just like I would expect it run less optimally if I was stuck in gridlock traffic in 100+ degree weather in altitude.
TheDonEffect is offline   Reply With Quote
Old 04-01-2021, 01:26 PM   #1566
1st86 Driver!
I've had 87 in mine twice. Once was the very first tank. The dealer filled the tank on delivery and I later found out they put 87 in it. Second time was during the pipeline break on the East Coast when fuel availability dropped to nothing, and you took what you could get. I ran two tanks then.
In both cases, I could tell no real difference, and the car seems to have survived it.
I mean, putting in 87 isn't a valve recall situation after all.
Dzmitry (04-01-2021), Transport3r (04-01-2021)
Old 04-01-2021, 01:37 PM   #1567
wbradley
Sarcastic SOB
wbradley's Avatar
The knock detection retards timing to protect the STOCK engine. I don't think it works for 87 fuell and 12 PSI boost though.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
Dadhawk (04-01-2021), Dzmitry (04-01-2021)
Old 04-01-2021, 01:41 PM   #1568
Sasquachulator
Pavement Grey
couldnt you just dump some octane booster in with some 87 if you had to?
I mean i still wouldnt wind it out with this type of fuel mix that but if you needed some higher octane without any available wouldnt this be a stopgap solution?
Search this Thread:
Advanced Search
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 232 01-03-2023 02:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) -- General Topics 10 07-11-2016 10:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) -- General Topics 4 06-15-2012 02:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) -- General Topics 39 03-24-2011 10:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 03:57 PM
