Old 08-11-2012, 02:30 AM   #71
ImAwesome
Drives: 99' M3, 13' SWP Brz
holy crap thats alot of whp for 9psi on a 2871
ImAwesome is offline
Old 08-11-2012, 02:33 AM   #72
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by BRZ-One View Post
that car is out of hand...
***In regards to the stock internal parts.
I talked with a tech at the Subaru dealership, he claims that the transmission is only designed to handle a 10% increase in torque. Everything was built with weight in mind and apparently the gearing in the MT is made of lightweight materials. They said they had the same issue with the WRX STI's when people started upgrading them, they were burning through their trannies and differentials..
I did some further snooping around trying to confirm or reject his comments, and it appears that TRD will be releasing a beefier transmission to handle additional torque to go in conjunction with all of the performance upgrades they'll be releasing. I guess time will tell, maybe sooner with that monster turbo.
the STI tranny has ALWAYS been a beast that can take a lot ob abuse.
the one in the WRX is a weak POS though.
subatoy is offline
Old 08-11-2012, 02:36 AM   #73
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Doesn't seem correct.. That's only an increase of 15 lb-ft of torque. The AZ6 the TL70 was based off of held approx 215-220 lb-ft.
ill86 is offline
Old 08-11-2012, 02:36 AM   #74
Tomzilla
Tomzilla's Avatar
Drives: '13 Premium MT BRZ
That's frightening..
Tomzilla is offline
Old 08-11-2012, 02:48 AM   #75
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
I need to change my underwear thanks
20valvewynn83 is offline
Old 08-11-2012, 02:49 AM   #76
subatoy
subatoy's Avatar
Drives: subatoy
Im worried about the transmission in this car as it's rated for low torque.
I found the article that talks all the specifics:
http://kaizenfactor.wordpress.com/20...e-know-so-far/
"For those of you who are looking forward to turbo or supercharge your BRZ / FR-S / GT 86 via the aftermarket, however, we must remind you of a crucial caveat that appears on the second photo of this article: “Medium Torque Capacity RWD 6-Speed Manual transmission (AZ6)”.
"the Aisin AZ6 (or J160 in Toyotaspeak) was deemed to be too weak."
subatoy is offline
Old 08-11-2012, 03:30 AM   #77
QFry
QFry's Avatar
Drives: '13 Argento FR-S
from another thread but...it appears they change that opinion or maybe i am drunk and reading wrong...
Originally Posted by Chewie4299 View Post
I was going to point put that you are wrong and add some supporting documentation until I remembered that we are talking about the auto here. You are correct. I felt I should still post since the information is useful.
As for the 6MT I believe it should be treated as a new tranny.
http://kaizenfactor.wordpress.com/20...n-or-is-scion/
Sent from my Galaxy Nexus using Tapatalk 2
Edit: Ne4w transmission (6MT) is NOT the AZ6 but is the all-new TL70...
QFry is offline
Old 08-11-2012, 04:00 AM   #78
ill86
ill86's Avatar
Drives: iG FR-S
Cool
Correct.
ill86 is offline
Old 08-11-2012, 04:16 AM   #79
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Another 76+ whp and im sold......... Good work!!!!......
BOSOZOKU STYLE BITCH........
FT-86GOD is offline
Old 08-11-2012, 04:17 AM   #80
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Guys, whatever they rate the trans for you can double it generally with a sprung clutch and good gear oil and it's fine. I pushed 440wtq from a transmission rated at 180 working torque. Now I'm pushing 385wtq from a 6 speed from a Maxima in my sr20 sentra. The RS6 is rated for 240 working torque. It holds just fine.
Coheed is offline
Old 08-11-2012, 04:29 AM   #81
francosolracer
francosolracer's Avatar
Drives: 13'FRS,10 TC(trad),09'370z(totaled)
In for updates
francosolracer is offline
Old 08-11-2012, 04:29 AM   #82
serialk11r
Drives: '06 AM V8V Coupe
Disabled direct injectors?
If so,
serialk11r is offline
Old 08-11-2012, 04:36 AM   #83
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
So if you can build an automatic solution, I'm up for the kit, depending on price (of course).
Kochinopride is offline
The Following User Says Thank You to Kochinopride For This Useful Post:
blackfireball5 (08-15-2012)
Old 08-11-2012, 04:53 AM   #84
ed209
Drives: '12 Mustang GT
i think the trans will be fine guys, i just wouldn't recommend doing continuous hard freeway pulls in 6th...
ed209 is offline
horsepower, old hp record, record, scion fr-s, subaru brz, turbo
Highest mileage FRS\BRZ Grishbok BRZ First-Gen (2012+) -- General Topics 199 09-22-2018 04:40 PM
Best cruising speed for highest MPG. BrandonFYIA Scion FR-S / Toyota 86 GT86 General Forum 95 03-29-2015 11:53 PM
Dynosty FR-S/BRZ Sound Tube Delete Kit Dustin@Dynosty Engine, Exhaust, Bolt-Ons 104 02-11-2014 11:35 AM
Dynosty Turbo Scion FR-S / BRZ (Dyno and Preview Video) Hal@Dynosty Forced Induction 33 08-25-2013 02:58 PM
new jdm legacy B4 uses FA20 turbo cyde01 Forced Induction 3 07-26-2012 03:00 AM
