| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: 17 Asphalt 86
#16 | |
Drives: VW GLI 6MT
However, internal combustion engines are heat transfer engines. If we forget about winter and summer blends of gasoline, E85 ethanol contains 81,900 BTU/gallon and E10 gasoline contains 111,800 BTU/gallon. If an E85 engine burns 70% more fuel than a gasoline engine (assuming the injectors and fuel pump can handle that increased volume), the E85 engine will burn 1.7 gallons of E85 fuel versus 1.0 gallon of E10 fuel. • 1.7 gallons (E85) times 81,900 BTU/gallon = 139,230 BTUs. • 1.0 gallons (E10) times 111,800 BTU/gallon = 111,800 BTUs. I know this is an extremely crude method to estimate power potential, but if this relationship holds true, the E85 engine has the potential to “release” about 25% more energy than the E10 engine. Based on a 200 hp engine that equates to an additional 50hp. Again, I acknowledge this down and dirty estimate may be fraught with error, but this seems to support your estimate of a 40 whp gain. |
| The Following User Says Thank You to Baldeagle For This Useful Post: | Windycitystig (11-03-2020) |
#17 |
Rust bucket enthusiast
#18 | |
Drives: 2018 Subaru BRZ
Why not load the stage 2 tune? If is tailored specifically for such header. Could've seen more actual gains vs the stage 1.
#19 |
#20 | |
My bad, seems reasonable.
#21 |
Drives: Subaru BRZ
Me? I got Pro Speed Racing one's. The exhaust guy that fitted them nearly wept at the beauty of the collector. $750.
The main gain is in removing the restriction of the cats in the headers. Where in Aus are you? Sent from my SM-G973F using Tapatalk |
| OFT stage 1 worth it on 2017+ | desertbound1024 | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 07-09-2019 08:51 PM |
| The WORKS 2017+ Stage 2 Turbo Kit is here! | WORKS | Forced Induction | 11 | 02-09-2019 05:27 PM |
| Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit | FullBlown | Forced Induction | 47 | 06-20-2018 03:38 AM |
| FRS single stage vs dual stage driver's airbag | mhiscott | Issues | Warranty | Recalls / TSB | 2 | 09-23-2017 04:43 PM |
| 2017 Toyota 86 Baseline Dyno vs OFT Stage 1 | JermMX5 | Software Tuning | 29 | 08-18-2017 08:11 PM |
