| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2018 Subaru BRZ
Just bought a 2018 BRZ, need some help!
Happy to finally be on the forums! I just purchased a 2018 BRZ that is mostly stock besides an oil catch can and Tein Flex Z coilovers. I want the car to be as stock as possible so looking to swap out the coilovers for a slightly used suspension. Does anyone know if there were any suspension updates made between 2017 and 2018? Or if 2017+ BRZ/86 suspensions are identical? I found some used 2017 SACHS dampers on Ebay and Facebook, so I'm wondering it it's a good idea to jump on those, or should I just wait it out until i find some 2018s for sale?
Thanks for your help! |
| The Following User Says Thank You to AJBRZ For This Useful Post: | NWFRS (11-03-2020) |
#2 | |
[insert cool phrase here]
Drives: BRZ Premium
Being that you have the '18 the oem ones are pretty good starting point.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
They are the same.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dzmitry (10-13-2020) |
Are the 2018 Toyota 86 stock suspension parts identical to those for the 2018 BRZ? My understanding is the suspension setup is the same between both cars after 2017. Seems to be a little harder to find the stock struts/shocks for the BRZ than it is for the 86.
Bump! Found some oem 2018 86 shocks/struts nearby. Want to confirm they will fit fine and the handling will be identical to the 2018 BRZ parts.
Drives: 2018 Subaru BRZ Limited with PP
Not 100% sure on the shocks/struts having the same settings as those in the BRZ, but they will definitely fit perfectly as they are interchangeable between the two cars.
#10 |
Thanks! yeah I figured the fit shouldn't be a problem. Just hesitating, as I rather keep the stock handling characteristics on the car, and not sure if the 86 setup is the same.
#11 |
Someone will answer this better as I don't know exactly, but I believe they are close to the same (in reference to suspension setup). Particularly the springs and shocks will not be significantly different between the two cars (if they even are) enough to change the handling characteristics much. Now if you're talking the PP Sachs dampers, then it's a different story.
#12 | |
| The Following User Says Thank You to AJBRZ For This Useful Post: | Dzmitry (10-14-2020) |
#13 |
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
The 2017 and 2018 are virtually the same with the exception of the radio head unit and the turn signal functions. The chassis are the same. Knowing this, I bought a 2017 (10/17 build) at a very good price April 2018. I was going to order a 2018 and pay cash, but the sales manager wanted to sell his last 2017 (wrong color) and gave me a hard time. Went to another dealer 30 minutes away and got exactly what I wanted and then bought an Ascent from the same dealer. I can't help myself from telling this cautionary tale about letting customers walk off the lot. Anyway, the only thing I did for my BRZ is change out the tires and left all else alone which suits my purpose. The general consensus among myself and my buddies is this: start with tires, then brakes, suspension and go from there. The seconds or fraction of seconds you may loose because of power can be made up by being able to go faster through the turns. A to B is never a drag race in a straight line. That is knuckle dragger stuff.
| I bought and totaled a BRZ. Then I bought another. | unhappymeal | BRZ First-Gen (2012+) — General Topics | 51 | 06-07-2017 07:54 AM |
| Bought | Anderzz | Want-To-Buy Requests | 7 | 08-31-2016 08:34 AM |
| bought her an frs | jsu1012 | Member's Car Journals | 79 | 04-14-2014 11:46 PM |
| FI Guys: Were you more excited when you bought your car, or when you bought boost? | husker741 | Forced Induction | 28 | 02-25-2014 03:57 PM |
| Best store bought or online bought wax | ThatManAnt | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 16 | 03-12-2013 09:32 PM |
