Old 10-07-2020, 10:07 PM   #1
RG4L
Question New Fuel Pump Install (AEM)
Hey guys! Im trying to get second opinions on this... i just installed my new AEM fuel pump but my car wont start... I clearly hear the pump starting, all the fuses are good and i know its giving spark cause It turned on before putting the pump... So basically its not getting fuel but the pump is actually turning on... Any thoughts??
RG4L is offline   Reply With Quote
Old 10-07-2020, 11:48 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pull a line off and see if fuel is actually building pressure
Old 10-08-2020, 01:55 AM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I just installed my new DW pump last week. I'm sure the procedure for yours will be similar.
Did you make sure to get the pump discharge properly seated using the O-ring(s) provided? I know the Deatchwerks pump included three O-rings in the kit along with some Superlube to lube the O-rings up with prior to inserting the new pump into the pump housing, but I actually used just one of them with the OEM spacer. If your pump discharge is not properly inserted into the housing you'll never build up the proper pressure you need.
Also, did you prime the fuel lines by turning the key (or press the button without trying to start the engine) on and off several times to eliminate any air in the lines?
Final question: Do you have enough fuel in your tank?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 10-08-2020, 07:38 AM   #4
Grady
Grady's Avatar
Remove fuel pump, double check your installation. Let us know what you find.
Old 10-08-2020, 08:02 AM   #5
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
There's a very useful video on Youtube from FTSpeed about installing that same pump. I'd check it out.
Old 10-08-2020, 09:10 AM   #6
RG4L
My ecutek reads pressure about 4 mpa. Idk if thats enough
Old 10-08-2020, 12:10 PM   #7
RG4L
So I took it apart and I placed the AEM fuel filter which is longer than the stock one so when the springs from the case compress as you put it in the tank they push the pump down and im thinking that pressure thats applied its making the filter go all the way down to the point where there's no gap between the filter so the fuel cant get in but idk
Old 10-08-2020, 03:41 PM   #8
MJones_RB
MJones_RB's Avatar
Don't all pumps work the same? You have to prime them first before they can operate? I remember there was a priming procedure of holding the gas pedal down to the floor and trying to start it. The engine won't start but the fuel will flow to the pump.
MJones_RB is offline   Reply With Quote
Old 10-08-2020, 03:46 PM   #9
RG4L
Oh I followed ft86 video but didn't prime it
The Following User Says Thank You to RG4L For This Useful Post:
MJones_RB (10-09-2020)
DIY: Deastchwerks 265c Fuel Pump Install xxscaxx DIY (Do-It-Yourself) Guides 35 01-24-2018 07:23 AM
Fuel pump upgrade install help Dream20b Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-23-2016 07:20 PM
AEM fuel pump, anyone w/ install experience? Gixxer86 DIY (Do-It-Yourself) Guides 1 10-15-2015 10:45 PM
looking for shop to install fuel pump ft86me Southern California 10 06-01-2015 02:02 PM
DIY: Fuel Pump Install-Video Ny Brz DIY (Do-It-Yourself) Guides 2 09-12-2013 10:59 AM
