Old 09-24-2020, 04:32 PM   #1
Optimoose20
Drives: Looking to buy
Help me understand steering feel on a wider tire (STX/DD)
Hi all,
I'm hoping to gain some clarification here and help make a decision regarding tire/wheel width. Basically, I am hooked on autocross, and my car is headed in the STX direction. My worry is this - I know 17x9 245 width is the ticket in this class, but if I'm only running 8-10 events a year, is it worth running those wider tires on the street?
Where I live, it isn't viable to switch wheels before every event, so I need just one set to do it all. My concern, more than absolute outright competitiveness, is maximizing steering feel. I know much of that is tire/sidewall dependent, but what general rules are there regarding tire width? I'd rather the car be as fun as possible for daily use vs being maximally competitive in class. Does that lead me to 17x8 225 width?
Does any of this make sense, or am I just totally off base? Any help is appreciated.
Edit: want to talk about scrub radius too. What offset should I be looking for?
Cheers,
Christopher
Optimoose20 is offline   Reply With Quote
Old 09-24-2020, 09:03 PM   #2
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
What is the barrier for you to switch wheels/tires before the event? If you can overcome that barrier it sounds like the ideal option for you (run a 225/45 17x8 for street and 245/40 17x9 for auto x).
Have you considered SSC class which uses a 225/45 tire size and more daily driver friendly suspension setup? You could easily drive (assuming weather permitting) that setup everyday and not change tires before events.
skylinekin is offline   Reply With Quote
Old 09-25-2020, 03:17 PM   #3
Optimoose20
Hey, thanks for the response! I actually drove an SSC car and wasn't too happy with it, although it may have been that individual car. It does sound like a closer fit for what I'm looking for.
Basically, I live in an area where it'd be tough to store extra tires and swap them, though I guess I could look for a garage/storage to make that happen.
What size do you run these days?
Old 09-25-2020, 04:01 PM   #4
black bnr32
Drives: FRS
In my opinion, no, not worth it. I’ve had overtired cars and they’re just not as fun. Especially if you enjoy power oversteer on corner exit.
black bnr32 is offline   Reply With Quote
Old 09-26-2020, 07:34 PM   #5
strat61caster
strat61caster's Avatar
Buy the 17x9s, get the good tires, still fun on the street imho, decent suspension tuning keeps it as lively as you like it.
ineedyourdiddly
Old 09-28-2020, 10:27 AM   #6
Racecomp Engineering
17x8 with 225/45/17 is the way to go for a street car, but 17x9 with 245 is still plenty good (especially with coilovers).
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Calum (09-28-2020)
Old 09-28-2020, 10:32 AM   #7
Also, when it comes to wheel/tire storage indoors, may I recommend taking up an interest in plants?
Meet Fernando Alonso.
- Andrew
The Following 12 Users Say Thank You to Racecomp Engineering For This Useful Post:
AllThePeat (10-01-2020), bcj (09-29-2020), BlueWhelan (09-28-2020), Calum (09-28-2020), churchx (09-28-2020), gravitylover (09-28-2020), new2subaru (09-28-2020), Optimoose20 (09-30-2020), Spuds (09-30-2020), Tcoat (09-29-2020), timurrrr (09-28-2020), ZDan (09-29-2020)
Old 09-28-2020, 10:43 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Why Fernando, not Kimi?
timurrrr is offline   Reply With Quote
Old 09-29-2020, 12:28 AM   #9
strat61caster
Because it's a fern...
Edit, could pick up a Kimi Ficunon.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Racecomp Engineering (09-29-2020), Spuds (09-30-2020)
Old 09-29-2020, 04:19 AM   #10
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I posted this in another thread a while back, but it's relevant here too:
Going bigger/wider isn't necessarily better in terms of feel in my opinion. My experience with 17x9 with 245/40 is:
Pros:
- heavier/more steering feel
- more confidence with high-speed turns/sweepers
- looks really nice when wheels & tires are more flush with the body
Cons:
- acceleration feels a bit more sluggish
- less agile with quick/tight transitions
- more body roll if you're not making any suspension changes
I missed the more agile feel, so I ditched the 9" + 245 combo and went to a 8" + 225 as a compromise between stock. But even now, I'm contemplating on downsizing again to 7.5" or 7" + 215...
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
Old 09-29-2020, 10:21 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
Personally, I haven't found wider tires to detract from handling or steering feel. If 17x9 with 245 is the ticket for STX, I'd just go that route. I drive on those sizes every day, they don't hurt the fun-to-driveness at all for me.
ZDan is online now   Reply With Quote
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Optimoose20 (09-30-2020), strat61caster (09-29-2020)
Old 09-29-2020, 10:37 AM   #12
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i daily indy500 255/45/17s with on issue. been doing it for almost 3? years. you can still autocross on them but they wont be as fast as yokos or REs. a bonus is that they make the steering feel heavier which is really nice
Breadman is offline   Reply With Quote
Old 09-29-2020, 04:37 PM   #13
Plumbus
Seņor Member
Plumbus's Avatar
Drives: '17 BRZ PP
How do the indy 500s feel as far as steering response, grip, communication before they break loose? im leaning towards those in 245/40r17 or the hankook ventus v12 evo2s
Plumbus is offline   Reply With Quote
Old 09-29-2020, 07:40 PM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Links to tests vs. other tires in their respective categories:
https://www.tirerack.com/tires/tests...y.jsp?ttid=235
https://www.tirerack.com/tires/tests...y.jsp?ttid=190
Improving Steering Feel sittinSideways Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-18-2014 07:52 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 05:52 PM
Steering feel with wider tires? TSY Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 07-26-2013 11:32 AM
Wider tire on stock rim..pics 6speed_Sam Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-07-2013 09:45 PM
Best Tire for Steering Feel Khyron686 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-12-2013 01:01 PM
